20 Most Recent
Makita 10" Dual Bevel Sliding Compound Miter Saw Questions & Answers
Cornice mitre angle
Try this ... http://www.constructionknowledge.net/public_domain_documents/Div_6_Woods_Plastics/Partial%20Carpentry%20pdfs/Finishing_Roofs_NAVEDTRA_14044.pdf
Concept MS100 mitre saw blade guard dillema.
I have changed the blade a few times, There is no need to remove the spring, etc. All you do is remove the bolt holding the guard and rotate it counter clockwise and it exposes the blade.
I am looking for parts for this saw. Anyone know where to get them?
How do u change out bushes on a makita ls1013
there are 2 black screw caps on the outside of the tool that need to be removed. USE a good quality blade and right size to avoid chipping the caps. UNPLUG TOOL first and remove the old ones and replace with new and reassemble. They might arc for a short period of time depending on the commutator wear. Run at NO LOAD for about 10 minutes. Let me know if you still have a problem
I can not remove armature caseing
Dave,The only thing i could offer would be try and look at one like that or a Bosch that ia all ready set up. of course there;s always the option of calling the company. I love those saws my 12 inchRigid takes up too much space.Good Luck.
Slide mechanism is stiff
linear bearing problemclean them with brake cleaner and compressed airthe balls should roll freely in the grooves inside bearingspush balls into the slots with compressed air to remove the dirt and then a little bit of oil and it should work.
Makita LS1013 Sliding Compound Mitre saw will not
my saw had this exact same problem, here's how i fixed mine.
okay so here's a schematic of the saw
http://www.toolpartspro.com/image/LS...-Makita-PB.pdf
whether you have the exact same issue as my saw, in order to further
investigate you need to get to the mechanism that locks the saw. To do
this you need to take the turn base (140) off the foot base (156) .
its really not too hard, just a little awkward setting the saw in
different positions to remove the various parts.
Specifically on mine I had issues with the threaded rod (118) not
screwing into the stopper holder (135). You'll see this part when you
flip the saw upside down.
So to remove the turn base(140) from the foot base (156)....
Remove the kerf board (108) and under you will see a big bolt, go ahead
and remove this. Then there are 4 more bolts which take off the guide
rule (117), this what your piece of wood is put against when making the
cut. Once these 5 bolts are out, the turn base can now be separated
from the feet. Now you'll have a better view of the mechanics and see
what is or isn't happening when you screw the handle to lock the miter
position.
Part 136 (turn stopper) is what actually wedges to a pocket in the foot
base which makes the saw lock. when you screw in the handle it
actuates this part. make sure that is happening. I had to take out
the threaded rod (118) and tighten it on a vice and work the stopper
holder (135) deeper onto the threaded rod. use WD 40 to help it a long.
You'll need to take off some other various parts to to get the rod
out. this will be obvious once you have everything turned over.
Now that everything is apart you can blast it with some WD40 or what you
think is best here. I used lithium grease. You'll see its especially
important to lube up the pivot post that the 2 bases center on, (where
the big bolt under the kerf board goes). also the slide plates (153) may
be rusty, they'll fall out when you separate the 2 base plates. clean
those up and spray them and anything else which will help with smooth
movement.
the only important item to check once everything is put back together is
the guide rule. this can be adjusted slightly in or out of square. Get
a nice framing square and make sure your locked in at 90 (or actually 0
degrees on the saw) Sliding the saw the full distance of the cut on
the square is ideal and maybe this was a good time to recalibrate that
movement anyway.
hope this works.
Ben.
My blade is not square to the table i,e if I make
Set your saw square using a combination square if you have one. Then to to adjust the saw to stay square there should be a gold coloured nut that you can adjust on the right side below the lever you use to unlock the saw when setting what angles you want to cut. Either move it in or out to get the proper setting. Hopefully this answers your question.
I was using my saw and the large spring popped
just found the problem, if you haven't fixed it yet let me know. There is no good way to reinstall the spring but I have done it numerous times and can talk you thru it, but you will need a press of some sort.
