20 Most Recent
Kobo Arc Questions & Answers
Kobo not accepting a charge
Lithium ION batteries are usually rechargeable. The use mode for these batteries is that there are a set number of recharges that equate to the life of the battery. Usually that life is approximately 1,000 charges.
If you use your battery to 50% then recharge, you can do this ~2,000 times. As the life of the battery is used up, the maximum charge lessens which means where you may have had 8 hours of play time when the battery was new, you will only have 6 hours as the battery life is used up.
In order for a Lithium ION battery to recharge there must be at least a small amount of charge left as a "seed" for that recharge. If you drain a L-ION battery down to zero, it may never recharge again or the max charge will be reduced to an insignificant amount of the original full charge. eg instead of 8 hours you may only get 15 minutes, or 5 minutes, or no minutes.
You are much better off recharging when 50% depleted than using it up til your product stops.
L-ION batteries cannot be repaired only replaced. Most cheap products using L-ION batteries cannot have their batteries replaced.
12/11/2020 6:30:34 AM •
Kobo Arc
Answered
on Dec 11, 2020
My kobo wont open the book, keeps loading but does not open
Does your Kobo turn off and on normally? Or is it stuck loading the book and totally not responding? If so, reset your Kobo. Look on the bottom edge of the Kobo - see the little pinhole? Stick a paper clip into there until you feel it push against a little switch. Remove the paper clip.
Is the Kobo working, but simply can't open a book? If it's only affecting a particular book, try deleting it and downloading it again.
12/10/2020 6:21:24 AM •
Kobo Arc
Answered
on Dec 10, 2020
How do i delete trash forever
Go to your trash folder select mark all then click delete forever. Then empty your trash as normal. This works in easy mail as well as web gmail
8/3/2016 10:01:15 PM •
Kobo Arc
Answered
on Aug 03, 2016
Kobo problems
If the books have been loaded from Kobo, you can go to their site and load them again (for free). If not, you would have to get them again from other sources and may have to pay for them again.
8/27/2015 9:33:06 PM •
Kobo Arc
Answered
on Aug 27, 2015
