20 Most Recent
Whirlpool 3362624 Washer Control Timer Knob Questions & Answers
I have a Whirlpool washing
I have a Whirlpool washer #LA8800XT and want to remove the Fabric Softener dispenser so I can remove the agitator. Does it just screw off? It seems to be stuck and I didn't want to break it if it didn't screw off.
7/29/2011 10:25:32 PM •
Whirlpool...
Answered
on Jul 29, 2011
Washer wont aggitate or spin
If you got some skills and want to learn try this steps.
Get the back guard of the machine out.Start any cycle and look at the motor and belt.If the motor spin, then the belts are loose or need to change them.find the appropriate belt and tension and start again.If the problem persist, i suggest to change your washer.
11/2/2010 3:29:03 AM •
Whirlpool...
Answered
on Nov 02, 2010
My washer finish washing sooner
What is the model # please?
The timer is faulty - and needs to be replaced.
With a model # - I can point you toward a replacement.
Thanks!!
1/8/2010 1:44:10 AM •
Whirlpool...
Answered
on Jan 08, 2010
WE HWAVE A WHIRLPOOL
Hi Bob has it got out of balance as that can stop the programmer or freeze it. Check to see if you can rock the machine do not need to use much force though. Will it empty and then rinse on it own will it spin on its own is it only on one setting... As for what parts I would want to Look/see first. David
12/25/2017 1:40:52 PM •
Whirlpool...
Answered
on Dec 25, 2017
Water at bottom of fridge
Pete, check if the fridge door closes properly. Also check if it cools ok. and you can hear the fan running.Check the settings.
12/16/2013 2:29:36 PM •
Whirlpool...
Answered
on Dec 16, 2013
Whirlpool washing machine toploader
If I were you I would replace the timer .I think that will solve your problem but if not depending on the age of your washer you could spend more on parts and labor than it's worth.Hope this helps you. Thanks.
11/18/2011 11:52:22 PM •
Whirlpool...
Answered
on Nov 18, 2011
