20 Most Recent
Invacare Pronto M51 Power Wheelchair Questions & Answers
Oil / gel leak
If it is coming from your motors, it could be very bad. i.e. motor replacement. Sometimes on the side of those motors there is a black plastic cap about the size of a quarter or half dollar, those fall out sometimes and allow gearbox grease to come out. This should`nt be confused with your motor brush caps which are about the size of a pea and have a small **** in them for a screwdriver.DO NOT TAKE THESE OUT. If the large cap has come out just stick it back in. If you can`t find it you`ll ned to call a dealer to get the part replaced.
If you can still find no prob,your probably going to have to go to a dealer.
Where is the reset button
Hello,you are my reason for being here,especially anyone with a wheelchair,i have a scooter myself & know what its like not to have your wheels.Please rate me as in thumbs up 1 to 4 for my answer.
Visit:WWW.ALLDATASHEET.COM Type in the right boxes-troubleshooting_2007 SHOPRIDER.pdf.It is 36 pages long 1 to 4 covers batteries,5 covers chargers,6 to 18 covers scooters & 19 to 36 covers wheelchairs & im sure you will be happy to see the part that you need to know about.Save it as a PDF File to your Adobe Reader + as i done print +save it to a polythene sleeve folder for future.Have a nice day i was so happy to have helped you,Colin.
Pronto M51, fully charged batteries, shows a #9 fault, , "communications fault"
check to make sure that there are no missing or bent pins on the lead and socket that connects the power module and the controller (joystick) often the small round plug and socket get bent pins and stop working, if bent try to straighten if missing then you will need a replacement lead or controller (joystick) ebay is a great place to pick up cheap wheelchair parts, do a search on google first as there are several types of controller and leads that can be fitted to this chair, look for a picture that matches the type you have and then search ebay for it, the controllers start from about £25 - 40 the leads from about £15 - £30 still much cheaper that getting a mobility shop to fix it.
Red,amber and two green lights a lit?
Solenoid Brake Trip
The parking brakes have a bad connection. Check the parking brake and motor connections. Make sure the system connections are secure.
check that the free wheel lever is disengaged, alway switch off the controller (joystick) before making adjustment or unplugging connectors as the error code will not clear until the joystick is switched off and on again. check connector blocks and wires for damage or being dirty contacts. clean use soft wire brush to clean the connector contacts.
My pronto m51 when i charge it the lights do not come on until i push shut off again
If you are referring to the three lights as the three colors red, yellow and green. Then you would normally get that. The circuit is telling you that something is attached to the chair, has faulty component or a motor unlocked. and you can't move.The rapid blinking would tell me that you have a controller fault or a motor fault and a rapid scroll left to right would be an inhibit. I would need to know which one it is doing to know for sure what what to look for. If it is just three lights then I would definitely look at the joystick and/or controller being faulty.
I have an older M51
Yes it does.
The new switch is the problem. The old toggle had a momentary ON when turned on and a jumper wire on two of the three toggle contacts.
Stability locking kit
The M51 does not have a stability locking kit. The Invacare TDX SP has a gas strut stability locking kit that just had an extensive recall campaign associated with it. Please describe your issue in greater detail.
Battery won't charge
Most likely you need new batteries. On the M51 powerchair the batteries are located in the center under the seat. Step 1 - remove the seat by pulling up on the swivel handle while lifting straight up, the seat weighs about 50 lbs. After removing the seat remove the center plastic cover by liting it off.
If you have an older model M51 the batteries will each have their own cover - to replace the batteries you will see several connectors that must be unplugged. The front and rear batteries each have different connectors so keep them separate. Lift out the batteries and follow the wiring for each replace the batteries. You will need 2 U1 batteries, available at sears or your local maedical equipment supply store ( Interstate has them too) Simply reverse the removal procedure to replace the batteries making sure you follow all the connections. - good luck
Tom
How to remove drive wheel
The drive wheel has a locking tab washer under the bolt which holds the wheel assembly on the end of the drive shaft. Step one is to bend the tab (or tabs) away from the side of the bolt. Put a socket on the bolt to remove it. Make note of the washer and lock tab orientation because there is another tab on the inside which locks into the motor shaft keyway. Spray lube into the shaft and keyway to free up the wheel and remove. A wheel puller is sometimes helpful here. When replacing the parts use Loctite on the bolt and tighten. The final step is to bend a lock tab up against the bolt head to keep it from backing out. The hard part of this whole process is removing the wheel assembly from the motor shaft. It may have seized on to the shaft. Place anti-seize or grease on the shaft after cleaning and before reassembly.
invacare com
