20 Most Recent
Dewalt 18v 1/2" Compact Drill/driver Kit Dc759ka Questions & Answers
How to remove brushes in a dc759 drill?
you cant replace the brushes on this drill it is a sealed motor. go this site the replacement motor is $ 38.77 http://www.ereplacementparts.com/dewalt-dc759ka-type-18v-cordless-drill-parts-c-1009_
Seized chuck.
I would continue to use the rust remover/penetrating oil products, put a pair of vice grips on the chuck grip and use a hammer to tap the grips. Hopefully this will free it up. It's not very elegant and you probably have already tried similar methods but it's the best idea that I have. Also you could soak the chuck portion in penetrating oil (chuck submerged only) overnight. Good luck!
Do you have to charge new batteries before use?
normally they carry little bit of charge but its alwys good to charge b4 u use them .. good way to check the battery charge is either there will be a battery meter on the battery like 5 leds on it or alternatively u do to bios of a laptop and check for battery meter
cheers
Why does my drill run hot
Maybe ur drill is not heavy duty type.You need to rewind the motor,but if i were you buy a new one.YOu may use the old one but its good for few minutes after using it.
I have a DeWalt D2570 - GB. Stopped working. On disassembly I found a bare wire from the capacitor. Where should it go?
A photo would greatly help with your issue, are both wires still attached to the capacitor?? in not, the capacitor must be replaced with one of the same value,
if the capacitor is ok, look for a wire with solder on the end but nothing else attached to it, or a solder point on a card with a hole in it or a solder joint that has broken free from the card,,, if you can solder well, and have the equipment,. it is good at this point because You'll need to re-solder them back together,,
again a photo will help me greatly in telling you exactly how to fix
How do I get a stuck bit out of my DeWalt dc 895?
https://www.youtube.com/watch?v=pNDgV_6k12E
Reverse and Forward Mode: Try putting the drill in reverse mode and hit the trigger, then forward mode. If that doesn't work, tap the tip on the driveway but don't slam it. It should release .
Use a Wrench: First, make sure that the chuck is in the locked position. Next, use an allen wrench to loosen the set screw on the side of the chuck. Finally, unscrew the drill bit from the chuck .
Remove Chuck Collar: Use a wrench or pliers to loosen the chuck collar and remove it from the chuck. Then, use a screwdriver or other tool to remove the chuck jaws and any other components that may be blocking access to the stuck drill bit. Once these components are removed, you should be able to access the drill bit and remove it from the chuck .
Wire placement on switch of DeWalt DWD520 hammer drill
Here are the wire placements for the switch of a DeWalt DWD520 hammer drill:
- The red wire from the motor goes to the top left terminal on the switch.
- The black wire from the motor goes to the top right terminal on the switch.
- The white wire from the power cord goes to the bottom left terminal on the switch.
- The black wire from the power cord goes to the bottom right terminal on the switch.
It's always recommended to double-check the manual or contact DeWalt customer service for confirmation, as wire placement may vary depending on the specific model and year of manufacture.
I have Dewalt D26501 and it will not run. I have a red light flashing at the rear of the drill, i'm getting full power but, as soon as you press the trigger, the red light flashers but, no go.
The red light flashing at the rear of your DeWalt D26501 could indicate a few different issues with the tool. Here are some potential causes and troubleshooting steps you can try:
- Battery issue: If you're getting full power but the tool won't run, it's possible that the battery is not delivering the correct voltage or is not making proper contact with the tool. Try removing the battery and reseating it firmly in the tool, making sure it clicks into place. If the battery is still not delivering power properly, try charging it fully or using a different battery to see if that resolves the issue.
- Trigger issue: If the red light flashes but the tool does not run when you press the trigger, it's possible that there is an issue with the trigger itself or with the wiring connecting it to the motor. Try checking the trigger for any visible damage or debris, and make sure it moves freely when pressed. You may also need to check the wiring connections inside the tool to ensure they are secure and not damaged.
- Motor issue: If neither the battery nor the trigger seem to be the issue, it's possible that there is a problem with the motor itself. This could be caused by a number of factors, including a burned-out motor or a malfunctioning component inside the tool. If this is the case, you may need to take the tool to a professional technician or contact DeWalt customer service for assistance.
Overall, troubleshooting issues with power tools can be challenging, and it's important to take appropriate safety precautions when working with them. If you're unsure about how to proceed or are not comfortable working on the tool yourself, it's best to seek professional assistance.
