20 Most Recent NEC Electra Elite DTU 16D-2 Corded Phone Questions & Answers
How to Change Time on NEC Dterm Series E phone
Press the "Speaker" button and enter 728 on the key pad. Then enter the correct time.
11/26/2019 8:44:37 PM • NEC Electra... • Answered on Nov 26, 2019
0answers
Cannot remove blinking red light on one of the
Depends on what blinking light it is, but try feature and the button. If its the red led at the top of the phone, it is a voicemail. Could also be DND, try feature, 69, feature.
1/26/2017 3:47:27 PM • NEC Electra... • Answered on Jan 26, 2017
Light still blinking after clearing voicemail on nec phone system
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
1/20/2017 4:32:34 PM • NEC Electra... • Answered on Jan 20, 2017
3answers
Need more rings
You have to change the rings from the voice mail server. If you don't know your way around the server, its best to get a local NEC tech although it is fairly simple to navigate. Depends on your skill. Typical default password for the server is NEC
9/14/2016 6:03:05 PM • NEC Electra... • Answered on Sep 14, 2016
Why my calls go directly to voice mail?
Is your system in nite mode? Feature 80 Feature toggles from day mode to nite mode on the main reception phone, if you don't have a nite key.
8/29/2016 11:37:11 PM • NEC Electra... • Answered on Aug 29, 2016
How to keep calls from going to voice mail
Remove call forwarding to the voicemail pilot extension. Either forward it to somewhere else or don't set any forwarding and it'll just keep ringing.
8/29/2016 11:30:49 PM • NEC Electra... • Answered on Aug 29, 2016
WHY MY PHONE WONT RING AT MY STATION
Ringing is set up by the system programmer, so talk to the office manager about getting the vendor to do this.
8/29/2016 11:28:47 PM • NEC Electra... • Answered on Aug 29, 2016
How to change the main greeting
The system administrator has access to the voice mail part of the system, can go in and select the bin where the message is saved, then re-record it.
8/29/2016 11:25:46 PM • NEC Electra... • Answered on Aug 29, 2016
Does not ring
If you recently dialed 4-0 or 4-1, those are Do Not Disturb and Call Forward codes. if this is what happened, then dial the cancel code for both, which is 4-2. This is with internal dial tone, don't grab an outside to do this. You could have someone dial your extension to test if the ringer is faulty. if their call comes in as voice announce, have them add a 1 to their dial sequence and their call should switch to audible ring, and you will know it's not a ringer issue. Adding a 1 can be done continuously if you want to switch back and forth.
8/29/2016 10:18:13 PM • NEC Electra... • Answered on Aug 29, 2016
How do i take the existing name on phone out and put mine in
it has to be setup in PABX programming. Your PABX admin can do this
4/27/2016 9:08:12 AM • NEC Electra... • Answered on Apr 27, 2016
How do you make it so you can see which lines are in use? Also, how to set up the direct talking with other people in the office Like a walky-talky by the push of a button?
Hi Fallon, while on the middle of conversation, please check the LCD display of your digital phone, you will see "voice call" then press the button for direct talking.
10/1/2015 7:26:29 AM • NEC Electra... • Answered on Oct 01, 2015
The feature light is blinking on one of our extensions
Try Feature 69 then feature. The phone might be set to DND
8/7/2015 4:46:35 PM • NEC Electra... • Answered on Aug 07, 2015
How do I change the names on the stations?
it depends on your type of phone system. On an Elite IPK system you need to enter program mode from x100 or x101 then goto function 4/18 per port and assign names. transfer key saves. need help remote billable support at www.ldtsnj.com
3/31/2015 9:16:51 PM • NEC Electra... • Answered on Mar 31, 2015
Dtu 16d ringer is off at other stations. I need to get the phone to ring on the other stations.
Hello, That would be a system ring group programming feature. It would depend on the type of phone system you have. NEC Elite 192, Elite IPK, Elite IPK 2. There are different platforms and this would determine how to program it.
3/4/2015 8:12:35 PM • NEC Electra... • Answered on Mar 04, 2015
NEC Electra Elite DTU 16D-2 Corded Phone Logo
365 questions posted
Top NEC Lands Phones Experts
ADMIN Andrew
ADMIN Andrew
Don A
Don A
RAJA NADEEM AKHTER
RAJA NADEEM AKHTER
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
NEC Lands Phones
  • NEC Lands Phones
Most Popular Question
change names stations
  • Lands Phones
