20 Most Recent
Mozilla Firefox Questions & Answers
I can not see netflix movie
try using IE for this matter and see if it helps.
If not, please do comment and I'll get back to you.
-Janis!
Reset firefox
Resetting preferencesActions * Edit this page * Translate this pageShow content customized for: * Windows * Linux * Mac OS * AllIf you want to reset your Firefox preferences, this article provides instructions on how to reset them through Safe Mode.To reset preferences: 1. Close down Firefox completely: At the top of the Firefox window, click the File menu, and select the Exit menu item.Close down Firefox completely: On the menu bar, click the Firefox menu, and select the Quit Firefox menu item.Close down Firefox completely: At the top of the Firefox window, click the File menu, and select the Quit menu item. 2. In Windows, click Start, open the All Programs list, and navigate to the Mozilla Firefox folder. In the Mozilla Firefox folder, select Mozilla Firefox (Safe Mode).Hold down the Option key, as you start Firefox.Go to your Terminal and run: firefox -safe-mode You may need to specify the Firefox installation path (e.g. /usr/lib/firefox-3.5). 3. Firefox should start up with a Firefox Safe Mode dialog. Note: You can also start Firefox in Safe Mode by clicking Start, selecting Run (or use the Start Search box in Windows 7 and Vista) and then entering the following in the text field: firefox -safe-mode 4. To reset your user preferences, click to put a check mark by Reset all user preferences to Firefox defaults. 5. To apply your changes, click Make Changes and Restart. Firefox will restart with your settings changed back to the defaults.
Mozilla Thunderbird Customer Helpline Call 1-(8O5) 225-669O Toll Free 24x7 Service Number
You probably have setup a POP access on your Thunderbird to download your mails from your webmail. POP will download all of your message from your wembail to your Thunderbird and will place all of these message in your Thunderbird's inbox. Regardless if those message where sorted in different folders in your webmail.
In order for your mails to stay on your webmail you need to enable a setting in your Thunderbird that will leave a copy of your messages in your webmail. You can follow the steps below to check this setting:
On your Thunderbird
1.) Click Tools
2.) Click Account Settings
3.) Click Server Settings underneath the account that you setup.
4.) Verify that 'Leave messages on server' is checked in the server settings section
I hope this one will help.
Can't figure out what opens .json files
Save .json to desktop, drag browser window smaller from lower right
edge till you can drag the .json into opened window., doubleclick
titlebar to restore browser full size. In the tab that opens with .json
data, click the bookmarklet. Another tab should open with links. You
can save as .htm by right click "save page as" web page complete.
I upgraded to firefox 4 how do i go back to
Hi. It is better to uninstall first your firefox version 4 then after that go to your drive C then go to program files then delete the folder mozilla firefox. Then install your firefox version 3.6.
No internet volume
If you have not updated to the newest version of FF, try doing that first. It sounds like you are having issues with browser plugins. You may have to un-install and re-install certain plugins if you already have the most updated version of FF.
Depending on what you have or do not have installed will depend on a proper course of action to fix the issue. Click on this
link to see more detailed information on your particular problem.
I hope this helps and good luck!
Forgot Master Security password for Firefox 24.0.3 How do I recover to reset?
In the Firefox location bar, enter the following location:
chrome://pippki/content/resetpassword.xul
and press Enter key. The Reset Master Password page will appear. Click the Reset button, to reset your master password.
Remember: Resetting your master password will remove all of your saved usernames and passwords.
How to unblock roblox.com
If someone has blocked you from accessing the domain roblox.com you can try a couple things. Try accessing the secure version of the site:
https://www.roblox.com/Landing/Animated
If that doesn't work, try using a proxy service. This will work unless your administrator has blocked access to the proxy service:
https://proxy.org/
