20 Most Recent Google Chrome Questions & Answers
All you have to do is right click on the bookmark bar scroll down to bookmark manager that window will open and that will let you make any changes to what you have on your bookmark bar.
Google Chrome | Answered 41 minutes ago
Just uninstall the current chrome and install the latest version of chrome if available. But just restart after uninstalling and after the installing the new one, this make some temp file and crashed file completely removed and new file to take place. So it will now work properly.
Google Chrome | Answered on Nov 12, 2019
Hello Nigel,
Try to set the proxy in the browser.
Open Google chrome >>To the right of the address bar at the end is a wrench type icon click on it >>Almost at the bottom of the list it says options click it >> click on the tab that says "under the hood" >> next click the button that Change proxy settings >> in the next box that pops up click on "never dial a connection" >> next click on the LAN button >> next ensure that all check boxes are clear, with no check marks in them click OK >> then click OK again that should bring you back to the Google chrome options box >> click close
Then close out chrome now wait about 10 to 15 seconds to allow for chrome to recognize the new settings >> Reopen chrome and you should be able to use it just fine.
I hope this solution will helpful for you.
Keep Smiling & Keep Using Fixya
Google Chrome | Answered on Nov 07, 2019
Please overview the follow link, it should be of help.
https://support.google.com/chrome/answer/6098869?hl=en
This error could be for two reason First you need to clear the browser cache and second one need to remove or disable the Internet secuirty if any...
  1. You can solve this problem by temporarily unistall or pause your Antivirus when connecting.
  2. (Remember to Rate) Sounds like a few things, but lets get most of the problems out of your way. So you want to ...
  3. The answer is in the question - you've been disconnected for some reason. Are you wireless or wired? if you are ...
  4. it is an antivirus problem... uninstall or pause your antivirus and then try to connect.it will definitely work..this is due to the wrong connections from chrome with antivirus..
Google Chrome | Answered on Oct 01, 2019
Sorry, this was too much to explain, so I just copied the error page.
Check the error you're receiving If you can load the webpage using another browser, but not Google Chrome, check the exact error you're getting by clicking the More information on this error link on the page. The rest of the solutions listed in this article are relevant if you're experiencing any of the following errors:
  • Error 2 (net::ERR_FAILED): Unknown error
  • Error 104 (net::ERR_CONNECTION_FAILED)
  • Error 105 (net::ERR_NAME_NOT_RESOLVED)
  • Error 102 (net::ERR_CONNECTION_REFUSED): Unknown error
Check for malware
We've found that malware is frequently the culprit on your computer that's preventing Google Chrome from connecting to a web server. Use free software available through Google Pack to detect and remove malware from your computer. Learn more about removing malware from your computer.
Clear your cookies
Cookies are files created by websites you've visited to store browsing information, such as your preferences for the website or profile information. A corrupted cookie file may be causing this error to show up. Follow these steps to clear your cookies (for Windows):
  1. Click the Tools chrome_toolsmenu.gif menu.
  2. Click the Under the Hood tab and find the "Privacy" section.
  3. In the "Cookie settings" section, click Show cookies.
  4. Click Remove all.
  5. Click Close.
Make sure Google Chrome is allowed in your antivirus and firewall settings
Each program works differently, so check your software's help resources for further instructions.
Adjust your proxy settings
Follow these steps (for Windows):
  2. Select Options.
  3. Click the Under the Hood tab.
  4. Click Change proxy settings. This opens the Internet Properties dialog.
  5. Click LAN Settings.
  6. Make sure that the "Automatically detect settings" checkbox is selected.
  7. Click OK for all dialog boxes.
Google Chrome | Answered on Sep 25, 2019
Webpage display issues: "This webpage is not available" (Network errors 2, 102, 104, and 105) Issue This message displays when Google Chrome is unable to find and load the requested web page.
Solutions Check your web address and Internet connection Double-check the URL in the address bar to make sure you're going to the right web address. If you've confirmed that you're going to the right web address, check whether you can open the same web page in another browser, such as Internet Explorer or Firefox. If you can't see the web page in any browser, the web page may be temporarily down. You should also make sure you're properly connected to the Internet.
Check the error you're receiving If you can load the web page using another browser, but not Google Chrome, check the exact error you're getting by clicking the More information on this error link on the page. The rest of the solutions listed in this article are relevant if you're experiencing any of the following errors:
  • Unknown error
To disable the proxy run this from the command line or modify your shortcut to run chrome:
"C:\Documents and Settings\YOUR USER NAME\Local Settings\Application Data\Google\Chrome\Application\chrome.exe" --proxy-server
See here: http://tiny.cc/A2tST
Encountering this problem following your first restart after installing Privoxy (which requires changing G-Chrome's proxy settings).
If, after installing Privoxy, you elected not to have it load on system startup, manually re-loaded Privoxy. Simply reconfigure Privoxy to load on startup and the problem should be corrected.
Click on the following links for more assistance:
Check for malware
Clear your cookies
  5. Click Close.
There are a number of possible causes for this, but here's the most obvious and widespread one. If this doesn't work for you, please reply (instead of just downvoting) and we can look at some other possibilities. But try this first (if you ar eusing Google Chrome as a browser):
  1. In Google Chrome, click on Tools menu (a little wrench icon), then go to Options.
  2. Click on the Under the Hood tab.
  3. Under "Privacy" section, untick the check box for Use DNS pre-fetching to improve page load performance. disable-chrome-dns-prefetching.jpg
  4. Click on the Close button.
  5. Refresh to reload the web page.
Here is why I receive this error:
When I had installed Google Chrome, I chose "not to participate to make our software experience better." I also do not use Google as my start page. What is happening is that the browser "phones home" against your choice and against your will, thus the error code. I have my firewall to block google.com and that is why I get this error, no matter what website I go to. Uninstall it and use Firefox, until Google respects your privacy.
Oh, and try it and you will see this is the truth. Block google.com with your firewall and go to any website....you will not be able to use Google Chrome and you get that error - it collects your personnel info. I had to use Firefox to post this. If you are comfortable with google tracking your web activity, by all means, use it.
Go into the Tools area, select Options, then in the Privacy section, turn off DNS pre-fetching. Worked well for me.
Follow these tips:
1: Check for malwares2: Make sure Google Chrome is allowed in AntiVirus and Firewall settings3: Fix Registry Errors4: Optimize Internet5: Clear Cookies:
  • Click Chrome menu on the browser toolbar
  • Select Settings
  • Click Show advanced settings
  • In "Privacy" section, click Content settings
  • In "Cookies" section, click the All cookies and site data
  • Click Remove all
If problem still occurs then use PC optimizer tool like Reginout that will not only clear cookies but will also optimize Internet.
Hi There,
I Just found this sollusin:
Turning off and disable DNS pre-fetching may actually solve and fix many web page not loading issue in Google Chrome. Here's how to disable and turn of DNS prefetching in Google Chrome.
SOURCE
Hi rosshan
Have you try to reinstall it, you can get google chrome from here :
http://www.google.com/chrome
The way to do it right : Choose Start- All Programs- Google Chrome- uninstall Google Chrome. After uninstall, restart the computer and then reinstall Google Chrome with the downloaded file from the link above (just double click on the file and follow the instructions)
Remember to save your favorites :O) You find the feature in the settings- bookmarkadministrator- Tools and export.
Hope that helps
Have a nice day
Please rate my answer
Google Chrome | Answered on Sep 14, 2019
There is one trick to use selenium IDE script in google chrome and IE. You can run selenium IDE script from command line to run it on gchrome. Here are the steps for the same. http://software-testing-tutorials-automation.blogspot.in/2013/07/steps-of-running-selenium-ide-test.html
Google Chrome | Answered on Jul 26, 2019
Google won't let you un-Google!
Google Chrome | Answered on Apr 23, 2019
You can report problem online here Gmail Is Up or Down
Google Chrome | Answered on Apr 12, 2019
If you have a google account, you WILL have a password but may have forgotten it. If you have forgotten your password, click the "Need Help?" link below the logon box and proceed to the password recovery/reset procedure.
Google Chrome | Answered on Feb 13, 2019
Google Chrome Logo
4,113 questions posted
Popular Products
Google Gmail
Google Gmail
2,496 Questions
Google Android
Google Android
557 Questions
Google Talk
Google Talk
320 Questions
Google AdSense
Google AdSense
110 Questions
Google Analytics
Google Analytics
31 Questions
Top Google Computers & Internet Experts
Ahmed
Level 1 Expert
Peter Dragonetti
Colin Stickland
Colin Stickland
Are you a Google Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Google Computers & Internet
Most Popular Question
when google chrome will support selenium
  • Computers & Internet
