20 Most Recent
2-Way Remote Starter Questions & Answers
1. How do I program a Crimestopper CHXMX6691 Key
hello
u will find a lot of wiring diagrams, codes etc and circuit diagrams help books and stuff like this at online places.. like reliable-store
for free
the girl in the chat box can help u instantly... im a frequent buyer there since Im a mechanic so take help from there
How do you access crimestopper techweb
If you are a professional installer then there are numerous technical support sights to access the wiring diagrams for the vehicle. However, what you really should be worried about is the EVO- ALL and how it connects to the Crimestopper unit that you are using. You have to be certain that the hardware and firmware versions are up to date on the EVO. You can find this by examining the label on the EVO unit and, the installation manual that lists the required versions for the vehicle.
Lost remote
get the manuals for your car starter this should have instructions for programming another remote
COOL START REMOTE NEEDS REPROGRAMMING
from http://www.crimestopper.com/techweb/InstructionBooks/RemoteStart/rs1300dp_1304dp_a_ops.pdf Note: All transmitter codes must be learned at time of programming!! The unit will learns up to 4 different transmitter codes. 1. Open Hood (If no hood pin installed with your system, then you must ground the Gray Hood pin wire). 2. Turn key to the ON position. (Pink wire must be connected.) 3. Press Programming button 4 times, then after a few seconds the unit flashes the parking lights 4 times. 4. Press button #1 of the transmitter to be coded. You should get 2 light flashes indicating the unit is waiting for a 2nd code, then press button #1 of a second transmitter, the unit will flash 3 times indicating its waiting for the 3rd code and so on. If all 4 codes are learned, the unit will automatically exit code learning mode, otherwise turn key off and close hood. See diagram below.
1tx ezze start remote
Either hit lock then the start button once if that doesnt work Hit lock and then start button 2x.
Remote starter
you have to get the exact remote as your old remote and it will tell you how to program it
Radio anti-theft code
see dealer if stock, if not stock., contact the maker of the RADIO.most radios are set to no code. (new)if PO (prev.owner or kids) set it. then you must guess it.there is no secret bypass. (not public,) RTM it says just that.if you could bypass it, radio thefts would skyrocket.At some dealers, they do have a fix but you just show up with registration in and match your drivers license. or no dice.
