20 Most Recent
DEI Python 1400XP Remote Start/Keyless Entry System Questions & Answers
My car is starting on its own
your system was set by accident for cold weather start, which will start it every 2 or 3 hours and run for 2 or 3 min, good thing about this is it will only run do this for 1 day, or untill the car is started with the key
Python 1400XP Remote Start and 08 Dodge Avenger issue
I take help from online websites that have this service like helping in repair some like reliable-store have instant help.. others are a bit slow which I don't prefer...
rest is up to u.. U can also get free manuals
I have a toyota camry station wagon 1995 with I
I take help from online websites that have this service like helping in repair some like reliable-store have instant help.. others are a bit slow which I don't prefer... rest is up to u.. U get free manuals
Python 1400xp installed by circuit city on a 2004
check your starter they act up like that, when it will not start if you could try to hit it with a hammer, pipe anything you can not on the solenoid but on the body of the starter if it start up you know that is your problem.
Remote starter will not restart my vehicle
If you have an alarm, or remote start with an alarm, you need to press and hold thethe valet button which would be hidden under the dash on the driver side, as you are turning the key sometimes remote starts have a starter disable or an alarm option to reset it that is what needs to be done, some systems even if you dont have an alarm go into a valet mode if your remote battery is old or you never reset it or the alarm kicked in or what have you. if this does not work for you then you will need to bring it to a dealership and have them do a total reset to the computer you can also try disconnecting the negative battery cable, but do this with the door open cause it will reset everything, and google the reset procedure for the key fob (remote).. do that reset for the remote and it should save you money from having to bring it to a shop or dealer.
hope this helps.
While driving the engine dies
If engine dies while driving and locks trigger then program your remote not to lock/unlock when turning on/off ignition. My car did that for a while before i figured it out and now my car actually runs 100% better and I've had no problems since.....
Engine wont shut off after vehicle started with remote starter
Tools: 10mm torque wrench
Step 1: Find the release bonnet lever or button in the car.
Step 2: once the bonnet is open, locate the battery pack.
Step 3: Then locate the negative charge and unplug the connector to the terminal by using your torque wrench.
Step 4: Then replug it in and close Start the car up and it should work.
Hopefully it works.
Phython demands a a key in the ignition to work.
Sounds like the bypass that was installed when the remote start was done lost programming, if you look under the dash and find some boxes under there reply back with some part #'s and I am sure someone can help you out.
I just had the computer
The way I understand your question is your vehicle main computer has been replaced and it is not working properly. Since you say you cannot start it, have them come and get it and do what ever additional programming is required. You cannot do this yourself. If this is a remote start issue and you can start your car with the key, take it back and have them make necessary repairs.
Thanks for your interest in FixYa.com.
