20 Most Recent Car APS921 Remote Starter - Keyless Entry Questions & Answers
How do I program the pr00e48s
Hi there's this website something like reliable-store and it is very amazing for manual for repairing servicing anything someone on fixya recommended it to me and I thank him even today They have full manuals and it's verrrrry cheap and mine I got free in offers 3rd time I also had an issue with the file so the girl replaced it in 30 mins there is one more but i don't remember its name it was 2 years back bitman something link this Try it out brother
1/31/2019 8:51:10 AM • Car APS921... • Answered on Jan 31, 2019
4answers
REMOTE STARTER NOT WORKING COMPLETELY
Here is page 2 of the owners manual, Hope it helps.
This will not start the vehicle if any one of the following situations exists;
The vehicle's hood lid is opened.
The gear shift selector is not in Park.
The brake pedal is depressed.
The safety control switch is in the Off position.
1. To start the vehicle, press and release the transmitter button two times within 2
seconds. The vehicle will start and remain running for the pre-programmed 5,10,15,20 minute run cycle. As a visual indication, the parking lights will flash or remain on depending on the setting by your installation center.
2. When you arrive at the vehicle, turn the ignition key to the ON position (not the spring loaded start position), then step on the brake pedal to disengage the remote starter. The
vehicle will continue to run, but now on it's own power.
NOTE: The engine will stop running before the pre-programmed run cycle has expired if you perform any one of the following functions;
-Press and the button on the keychain transmitter two times within 2 seconds.
-Depress the brake pedal.
-Open the vehicle's hood
-Place the unit in the safety control disabled mode.
PRLED SAFETY CONTROL SWITCH
The Push-Button LED control switch allows you to temporarily disable the remote starting function of the system. This recommended whenever the vehicle is being serviced. To place the system in the service mode:
1) With the system disarmed/unlocked, and the ignition switch off Press and Hold the PRLED on.
2) Turn the ignition switch on, off, on, off, on, off.
3) The LED begins to flash two short flashes followed by one long flashes and continues this pattern until returned to normal mode of operation. This puts the unit into the R/S Override mode indicating that the remote start is in the service mode and will not start from RF or any other input Posse or otherwise.
To Exit R/S Override Mode
1) With the system disarmed, Press and Hold the PRLED on.
3) The LED turns off indicating that the R/S unit is fully functional one again
6/19/2016 2:47:58 PM • Car APS921... • Answered on Jun 19, 2016
Remote will only start when i am close to vehicle
It depends on many things - mostly the range of the system itself and especially where you located the remote antenna. Some installers don't use the antenna and that will limit range severely. Most manufacturers want the antenna routed up the windshield pillar and mounted near the top of the windshield glass. This gives best reception since glass does not hinder the RF signal. OF course, a weak battery in the remote can cause range issues as well.
11/25/2015 12:22:40 AM • Car APS921... • Answered on Nov 25, 2015
Where is the valet button
On most audiovox products it's built into the led witch is mounted on windshield if not look for black push button on driver side under dash or the kick panal
8/10/2014 11:24:34 PM • Car APS921... • Answered on Aug 10, 2014
Mitsubishi remote manual
Might need to replace the battery in remote start should not need a manual to do that
1/3/2014 8:53:56 AM • Car APS921... • Answered on Jan 03, 2014
Car wont start
check the battery in the key case . replace with a new one.
6/10/2013 5:32:47 AM • Car APS921... • Answered on Jun 10, 2013
Elvatoe prooe4bs
I found this to be a battery problem in the key. Had a new battery fitted and problem fixed. The immobiliser works in very close proximity of the key and so it allows the car to start but there is not enough power in the battery to transmit to the receiver for the locks.
6/10/2013 5:19:08 AM • Car APS921... • Answered on Jun 10, 2013
0answers
I bought a car with this starter (below)and no one
I'm not sure about trunk but to start the engine press twice green buttun and engine should start and to shutt it off press green button once.
2/5/2013 1:09:52 PM • Car APS921... • Answered on Feb 05, 2013
Car APS921 Remote Starter - Keyless Entry Logo
98 questions posted
Top Audiovox Vehicle Parts & Accessories Experts
xxxxxx xxx
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you an Audiovox Vehicle Part and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Audiovox Vehicle Parts & Accessories
Most Popular Question
help viper 791xv install
  • Vehicle Parts & Accessories
