20 Most Recent
DLX 500 Remote Car Starter Questions & Answers
Bulldog Deluxe 500, remote not starting the the vehicle
Remove the battery in your remote for 15 sec, then put back in, start your car with your key, wait 15 sec, while the car is running press the * star button 2 times, it should beep , if not try it again, if still nothing post me back and we can go from there
I have a Bulldog Model 500 remote started
I take help from online websites that have this service like helping in repair some like reliable-store have instant help.. others are a bit slow which I don't prefer... rest is up to u.. U get free manuals
1999 Durango
try buuldog manufacturer on line help ,possibly needs programming via sequence on remote button
Bulldog security 500d red light
I would first of all take apart and use an electricle spray to clean it ,,replace with new batteries, and you never know your look
I have the Bulldog Security DLX 500 installed in an 05 Nissan Pat
What type of car is it installed in? The problem is most likely either that there is a factory anti-theft that you have not disabled, or there is a second or third ignition wire that is not connected. If you can give me the year-make and model I can give you a specific wire connection.
Thank you
Headlamps work all the time
pull the parking light fuse from the wire harness on the remote starter, it should be a blue 15amp not the green 30 amp, if that works you wired the parking light wire to the wrong one, if not post me and we will go from there
How do I start my car?
If you mean to keep the car running once it's already been driven, and you want to have it remain running, but take your keys with you, put the vehicle in park, release the brake, with the key in the "run" position, push the same button you use to remote start the car. You'll have the relays click, and the parklights (if connected) will come on. Don't touch the brake!! Turn key to "lock" position, remove key. Vehicle should remain running for the set amount of time like normal remote start operation. You may now lock your car with the remote, too. When you return to your car, turn key to "run" position, when you step on brake pedal, the remote start will cease operation, and you can drive car as if you had remote started car from a standstill.
Bulldog deluxe 500 doors will not operate with the remote
Bulldog has it BAD that Way I have seen this More than Once I nstalled one In A Chevy Blazer and 7-8 Months Later it Started "STARTING ON ITS OWN There HELP LINE NEVER HAD An Answer for Me So I Disconnected it Keep Tryin or Send it Back To them Sorry Not So Helpfull I Just Would Disconnect it
