20 Most Recent
LeapFrog Tag Reading System Questions & Answers
I haven't gotten past the setup screen because it
You need to contact the seller. The device has a detection problem, which is not something you can correct, unless the toy has instructions for how to reboot it. It sounds like a defective sensor.
My tag reader won't say my child's name
The two responses to this question have nothing to do with the question! I have a similar problem. I have a brand new Tag, connected and uploaded books just fine, but in my case it doesn't say any name when turned on/off.
I installed my leapfrog connect for my Tag reader.
it depends on what Operating system your using, if xp then goto devices in the control panel and click on detect new devices, also check there if the usb drivers are installed, sometimes you have to install the software before plugin it in. if it's win7 then again click on devices and also check my computer when the usb is connected, and again install the software before plugin it in. best regards.
My daughter's Leap Frog Tag reader pen will simply
Hello I will try to help you. If the pen was working up until the batteries died then the problem logically would be solved by putting in new batteries. That said, remove the "new" batteries and install them in another device to be sure that they are good. Some new batteries die in the package before being used.
Then make sure you are putting the batteries in correctly, pay attention to the + and -.
Finally, you can clean the ends of the battery chamber by using a pencil eraser and rubbing it on the metal contacts.
Let me know if one of these things fixes your problem as I have additional ideas.
