20 Most Recent
Sony ST21i Xperia Tipo Black Questions & Answers
Unresponsive touchscreen Xperia Tipo
you have to go local store to purchase cheaper spear parts if you send me your address I can help you to which market you have to go for cheaper spear parts
Reset unlock pattern
Usually after entering the incorrect pattern five times it will lock up for 30 seconds, but it will also provide an option on the bottom of screen that says "Forget pattern?" You must enter your User name and password to reset the pattern.
Phonebook not loading
The range of possible root causes is huge, it is almost impossible to tell exactly what might be the problem. Before getting the device to Sony for check, i would simply try to reinstall the Operation system on the phone with the help of a pc software called Sony Update Service. This is my only guess or advise.
Use Sony's PC companion(Find on there website) to do a factory restore(You will lose everything saved on the phone)
1586-552-0920
what kind of problem are u having with this device? you didn't explain in your post.
Software
Remove battery, sim, sd card, and leave for 15 minutes. Place everything back in and restart. If that doesnt work, it might need software upgrading.
How to open lock
I forget my password and I drawn my password 6 time now it locked my phone model no micromax a89 plz sotout my problem
How to unlock my xperia tipo as i have forgotten my password and security question
ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will Solved
