20 Most Recent
LeapFrog Leapster Learning Game System Questions & Answers
My daughter has a Leapster 2 that is only about 2
Answer
I had the same problem and here is the answer I found
at leapfrog.com which fixed my daughter’s disney princess leapster 2’s
problem. Good luck!
If your Leapster2 does not respond to the stylus pen, it needs to be calibrated. Calibrating the Leapster2 is easy:
1) Ensure that a cartridge is not inserted
2) Hold down the Hint (?) button while turning the unit on. Continue to
hold the Hint button down until the LEAPSTER menu appears.
3) When the LEAPSTER menu screen appears, press the A button
4) Touch each of the crosshairs that appear with the stylus
5) Restart unit
1/10/2011 10:12:31 PM •
LeapFrog...
Answered
on Jan 10, 2011
When we touch the screen nothing happens - changed
This is usually cause by extremly hard impact which can dislodge the contacts between the Screen and its mating contact on the circuit board. This requires opening the device and attaching/repositioning the connector, whilst the divice is open you should place a small amount of hot glue on the outer part of the contact to prevent it moving. DO NOT use solvent based adhesives or super glue as this will severly damage the device. If this does not solve your problem contat me on
[email protected] and I will try to assist you further.
6/20/2010 12:35:29 PM •
LeapFrog...
Answered
on Jun 20, 2010
Touch screen doesn't work
Contact Customer Service they may be able to replace the unit even after warranty 800-701-5327
10/13/2009 7:40:11 PM •
LeapFrog...
Answered
on Oct 13, 2009
Touch screen not working
Contact Customer Service they might be willing to replace the unit even after warranty has expired 800-701-5327
10/13/2009 7:30:27 PM •
LeapFrog...
Answered
on Oct 13, 2009
Put new batteries and it won't come on
There are a number of possible reasons your toy may have stopped working. Sometimes it helps to clean the battery compartment with a dry cotton swab or cloth. Rub the gold contacts inside the battery compartment to release any dust or film. You can also use an eraser to 'erase' and clean the contacts. Once you have cleaned the contacts, please make sure to install new non-rechargeable batteries before turning your unit on.
If the toy still does not work, it may have been dropped or handled improperly
10/13/2009 7:27:50 PM •
LeapFrog...
Answered
on Oct 13, 2009
Cant sign in
2) Hold down the Hint (?) button while turning the unit on. Continue to hold the Hint button down until the LEAPSTER menu appears.
5) Restart unit
8/11/2009 7:54:52 PM •
LeapFrog...
Answered
on Aug 11, 2009
We have leapster two, we have power but the pen
5) Restart unit
8/11/2009 7:44:49 PM •
LeapFrog...
Answered
on Aug 11, 2009
