20 Most Recent
Maytag Epic z Front Load Electric Dryer Questions & Answers
Dryer runs but does not heat up
The heat element may need replacing. They burn out once in a while. Check all fuses as well and if you have it apart make sure all wires are plugged together where they are suppose to be. We had a wire that pulled apart and the repair man came and five minutes later he left with me paying a bill.
Maytag old dryer flame will not ignite when glow thing lights up
The 'glow thing' is called a Thermocouple and is a safety device that makes sure that there is a flame before the main gas valve to the burners opens up.
Because it is a gas appliance and the very REAL danger of explosion, all gas appliance must be worked on by a gas certified technician. It is not a big job and they normally carry thermocouples in the van.
Where is the pilot light on a Maytag dryer
what is the model number? free standing pilots have been gone for several years. Google your model number and include parts.
This will give you sites that sell parts.
You most likely have and hot surface ignitor.
What is the electrical capacity of Maytag MDG9700BWW?
https://search.yahoo.com/search?fr=mcafee&type=E210US1494G0&p=the+electrical+capacity+of+Maytag+MDG9700BWW%3F
Then check related searches
MOTOR: 1/4HP,120 volt,60 Hz,single-phase,thermally protected against overload,auto-reset. EXHAUST:Use a minimum of 4"(10.2 cm) diameter rigid aluminum or galvanized steel duct. Never use plastic,nonmetal or combustible duct. HEAT SOURCE/ELECTRICAL REQUIREMENTS: Electric model- 5,300 watt nichrome helix coil; 240 volt,AC,60 Hz; 30 amp fuse. Gas model-Single port burner with automatic electric ignition; 22,000 BTU/hr. 15 amp fuse. Self-adjusting valve automatically compensates for variation in gas pressure. WEIGHTS (Crated/Uncrated):
What dose it mean F07 Maytag dryer
The F70 indicates a communication error code between the main control on the top left and the user interface on the front. Unplug the machine and remove the top. Check the connection on the board in the white plastic housing on the top left. Next check the connections on the board on the front.
