20 Most Recent Williams-Sonoma Nespresso U Espresso Maker with Aeroccino Plus Automatic Milk Frother, Questions & Answers
The machine has started the "decalcification" process.
When the three lights are flashing just press the three buttons at the same time (with three fingers) and relase when you hear a beep. After that your all good.
This happens when you press the three buttons at the same time when cleaning for example.
Hope it helps!
Williams-Sonoma... | Answered on Jun 21, 2019
Same thing happened to me this very morning and I found the answer above worked-I unscrewed the hopper completely cleaned out some residual beans and then put it back and sure it was locked and the lights stopped flashing and it worked
Coffee Makers &... | Answered 2 days ago
These machines are so expensive ($800) and so complicated, any work needs to be done by a service technician. The power button switches it on, the water heats up, it builds pressure and then a switch should stop the heater.
https://www.espressotec.com/pavoni-napolitana-parts-diagram.html
When was the last time it was descaled, or stripped and cleaned?
Wow, after 8 years of inactivity it will need a full service. Full strip down and clean, new o-rings and possibly a new pump. Everything will have dried out inside.
Due to a software scripting glitch on the website, I am not able to reply to comments. I normally can on my iPhone, but apparently not today, even after trying all the tricks. I hope you come back and check on the post!
Coffee Makers &... | Answered on Feb 12, 2020
water is too hot. When the pod is pierced and the water valve is opened, high pressure steam comes out and bang!
contact the maker.
Coffee Makers &... | Answered on Feb 04, 2020
Order the repair manual directly from DeLonghi.
Coffee Makers &... | Answered on Feb 01, 2020
Williams-Sonoma Nespresso U Espresso Maker with Aeroccino Plus Automatic Milk Frother, Logo
18 questions posted
Top Williams-Sonoma Coffee Makers & Espresso Machines Experts
ThaMp3Doctor
ThaMp3Doctor
Pierre Laplante
Marvin
Marvin
Are you a Williams-Sonoma Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Williams-Sonoma Coffee Makers & Espresso...
  • Williams-Sonoma Coffee Makers & Espresso...
Most Popular Question
nespresso u all lights flashing pod
  • Coffee Makers & Espresso Machines
