20 Most Recent
National Kids Mini Cooper Racer Ride On Car Questions & Answers
Hi i have a injusa
Hi, Check the charger that it is charging.Use a volt/ohm meter to check for power on cable. If battery does not hold a charge. replace battery with new one. Hope that helps.
Why does the charger get hot?
It will do so when working hard. This will happen when the battery is fully charged, or when it is dying and cannot take a good charge. Ni-Cads do this after a while. In both cases it is because the battery has a high resistance to further current passing through it.
I have a new red
if it goes full force for a moment it got some kind of charge so its not the charger sounds like the cells in the battery are bad
24 Volt Mini Racer Ride-On Toy
I purchased a bulk lot of racers at a recent auction that included 3 mini racers but discovered after I had bought them that none of them had batteries so I'm thinking I may try to sell them minus the batteries to people who need parts. What are you looking for or are you interested in buying the whole car? Send me an e-mail at
[email protected] if you're interested.
Repair of Mini Racer
That probbly means the motor is permanently unfixable- you could get a new motor or get a new racer at toys R us
National Kids Red Mini Cooper Not holding a charge
You can swap rechargeable batteries in both mini cooper to confirm that is it battery charge storage issue or its drive circuit. If problem shifted to OK mini cooper then its battery that does not store charge to drive and if problem still remain in same mini cooper then its drive circuit problem.
Thanks.
