20 Most Recent
Konami Karaoke Revolution: American Idol Encore Questions & Answers
PS3 American Idol Encore - game won't load with no saved game
I had the same problem and this is how I fixed it.
1. I ejected the game and turned the system off
2. I unplugged all of the remotes. (even the drums for rockband if you have them plugged into a usb port)
3. I connected the cable to one of my wireless remotes and plugged the usb end of the cable directly into the front of the playstation console
4. I cut the console back on and it automaticly assigned that remote to position # 1 (the lights on the remote will flash at first and then the light above #1 should remain on showing that the remote is in position # 1)
5. I inserted the game disc and it started just as it had before, except when I had the option to hit the red circle button to load without saving the button actually worked and it went to the next menu where you can begin to play the game.
I hope this solves your issue as well because I called Konami tech support (310-220-8330) directly and all they told me was try it in another ps3 to see if it works and if not I was going to have to pay to ship the game back to them so they could replace it. I just got lucky and thought I would try to reassign my remote without any others being plugged in to see if it would work and it did. Good Luck!
PS3 American idol encore 2 mic problem
I GOT THIS TO WORK.
First, make sure ur PS3 system update is full updated.
1) Turn on PS3
2) make sure all the mics were unplugged
3) plug one mic in
4) accessories setting -> audio device
5) select logitech as input
6) plug in the second mic
7) accessories setting -> audio device
8) scroll thru the input device, make sure it lists both logitech, this makes both mics are sync'ed to ur PS3
9) select the FIRST logitech device in input device
10) save setting, restart ur PS3
11) start the game as usual
12) in duet mode, both mics should show, if one is working and the second one doesn't, one forum suggests that u unplug the one that works and replug it while u are still in the menu.
Works for me, I hope it works for you. Cheers.
I have the american idol
I bought this for my sister and she had the same problem, they took it back and got another one, had the same problem....turns out it is their tv, they have an older tv, so she tried it on my dads lcd tv and it worked great.
Microphone not working on ps3 w two connections
you should be able to plug each mic into a usb port. (they are the holes on the front of the machine) they each need to be plugged in separately. If this doesn't work there may be a problem with the usb port.
Ps3 mic for american idol
u have to go to system setting and than go to accessories setting, and there go to sound,go to input switch to logitech, don't for get to press okay
Hi I've got a babyweaver
Sounds like you are missing the central support rod or bar that connects the Babyweaver swinging crib to the stand, providing stability and support for the crib. This component is crucial for maintaining the structural integrity of the crib and ensuring safe usage. Here are some steps you can take to address the missing part:
1. Contact the Manufacturer:
- Reach out to Babyweaver or the manufacturer of the swinging crib to inquire about obtaining a replacement central support rod.
- Provide them with details about the missing part and the specific model of the swinging crib to ensure you receive the correct component.
2. Check for Spare Parts:
- Check if the swinging crib came with a user manual or assembly instructions that may have information about spare parts or replacement components.
- Look for any contact information provided for customer support or spare parts inquiries.
3. Online Search:
- Conduct an online search using keywords such as "Babyweaver swinging crib central support rod" or "Babyweaver crib replacement parts" to see if you can find the specific part for purchase.
- Explore baby product retailers, online marketplaces, and specialty stores that offer replacement parts for nursery furniture.
4. Local Retailers:
- Visit local baby product stores or furniture stores that carry nursery items.
- Bring the existing part (if you have one side of the support rod) to help them identify and match the missing component.
5. Custom Fabrication:
- If you are unable to find a suitable replacement part, consider contacting a metal fabrication shop or a carpenter who may be able to custom-make a central support rod that fits your Babyweaver swinging crib.
- Provide them with measurements and details about the required specifications for the part.
3/22/2024 3:29:32 AM •
Toys
Answered
on Mar 22, 2024
I have a new model teddy ruxpin and my 2 year old daughter tripped and dropped him. His lights all come on but his app and sound are not working
It sounds like the drop may have caused some internal damage to the electronics or wiring of the Teddy Ruxpin toy. Here are some steps you can take to try and troubleshoot the issue:
- Restart the Toy: Sometimes a simple restart can resolve minor issues. Try turning off the toy completely, including any power switches or buttons, and then turning it back on again after a few moments.
- Check Battery Compartment: Ensure that the batteries are properly inserted and making good contact with the terminals inside the battery compartment. If the drop caused any displacement of the batteries, it might affect the toy's functionality.
- Inspect for Physical Damage: Carefully examine the exterior of the toy for any signs of physical damage, such as cracks, dents, or loose parts. If there's visible damage, it may indicate internal damage as well.
- Test with Different Devices: If the Teddy Ruxpin toy connects to a separate app or device for sound playback, try connecting it to a different device to see if the issue persists. This can help determine if the problem lies with the toy or the connected device.
- Contact Customer Support: If none of the above steps resolve the issue, it's possible that the drop caused internal damage to the toy's electronics or wiring. In this case, you may need to contact the manufacturer's customer support for assistance. They may be able to provide further troubleshooting steps or offer a repair or replacement option.
Keep in mind that since the toy is relatively new, it may still be under warranty, which could cover repairs or replacements for damage caused by accidents like drops. Be sure to check the warranty information or contact the manufacturer for guidance on warranty coverage.
3/21/2024 2:25:15 PM •
Toys
Answered
on Mar 21, 2024
Fisher-Price J7485 T-Rex stopped moving
Check Batteries: Ensure that the batteries are properly inserted and have sufficient charge. Sometimes, a low battery can cause the toy to stop functioning.
Switch On/Off: Confirm that the toy is switched on. Some toys have an on/off switch or button that might accidentally get turned off.
Connections and Wires: Inspect the wires and connections inside the toy. Loose wires or faulty connections can lead to malfunction.
Obstructions: Look for any obstructions or debris that might be preventing the T-Rex's movement. Clear any blockages.
Reset: If there's a reset button, try pressing it. This can sometimes resolve minor issues.
Contact Customer Support: If none of the above steps work, consider reaching out to Fisher-Price customer support as below.
https://service.mattel.com/us/ContactUs.aspx
2/22/2024 2:51:59 PM •
Toys
Answered
on Feb 22, 2024
Can I fix an error on my orthofix 2212 it shows
Why are you guys giving answers to fix a printer when the OP is asking how to clear the error code on an orthofix bone growth stimulator used to help the bones fuse together after back surgery... I'll give my best guess as I am having the same issue. They are set to last a certain amount of time and designed to stop working after that set time. In my case I got the device, postponed my surgery and my orthofix wouldn't work after I actually had the surgery.. 2nd best guess would be a battery issue because I can charge mine fully, turn it on for about 10 min, put ot back on the charger and it flashes all 4 bars like its completely dead.. but there is a number you can call that can help you more than I can, 18005354492
1/17/2024 9:11:13 PM •
Toys
Answered
on Jan 17, 2024
How ca i overcome my
Tried and tested solutions.
Go out and take deep breath and in your mind say 'I want to get rid of this bad habit"
1/4/2024 6:43:12 PM •
Toys
Answered
on Jan 04, 2024
