20 Most Recent
Air Hogs Havoc Heli Helicopters Questions & Answers
Havoc heli will not charge
As far as the green light on the charger not coming on: after I tested
the batteries in the remote, I found that it was due to 2 of the 6
batteries in the remote control being dead (0.1volts) The charger
probably sucks the power out of the #1 and #6 battery.
Make sure all batteries in the Remote have the same charge.
Also, there seems to be a loose contact in the charger plug prongs. You will have to find a way to sit the helicopter so that it stays in contact with the prongs while charging. Mine has to be on it's side to keep the green charger light on.
Spins to left non stop and trim wont correct it
the cause of this issue is hair or something preventing the tail rotor to spin properly.. i had this issue and checked mine over very good, noticed the hair in tail rotor, and then took a needle to fish IT ALL out.. if u dont get it all.. it wont trim properly cause it cant spin fast enough
We broke the stabilizer of our air hog havoc heli. Where can we get replacement part?
I replaced a broken stabilizer successfully with a regular paper staple (like the kind in a red Swingline stapler). It's the right length! I punched the staple through the stapler to bend the ends, rounded them a bit with needle-nose pliers to fit over the stabilizer pegs, then used the pliers to tighten the loops. (I got a couple of Air Hogs recently at a garage sale, but one was missing a stabilizer. Excited that it works now!)
How do i pay someone via paypal
hello you should to go for internet help to let you know how to pay from paypal.or you should try this http://www.superithub.com
My green air hog helicopter
There is a problem on the motor gear, check the underside where you could see a big gear that should spin when you try to lift the helicopter. Check both big gears if they rotate/spins.
Usually the problem is the small gear on the motor shaft that is not aligned to that big gear. Check on it and adjust the small gear of the motor.
Hope that copter flies high.
Thanks for asking FixYa!
