Tip & How-To about Sansui VRDVD4005 DVD Player/VCR
Fix for various problems
I've seen various problems get resolved with Computers, Digital
Cable Boxes, Routers,and Satellite Receivers by simply unplugging
the unit. If all else fails, give it a try. For my Sansui VRDVD4005, I
unplug it and wait about 10 minutes, then sometimes wait 30 minutes
or more for the "auto clock" setting to return.( AS IF IT WERE JUST
TAKEN OUT OF THE BOX) You can set the clock manually if you
don't want to wait when it starts blinking and you will have to set
up your channels again. This has fixed DVD freeze-ups, VCR timer
recording problems, and all the C### error codes in the troubleshooting
section for my unit at one time or another. Good Luck to all.
Sansui VRDVD4005 DVD Player/VCR Logo
hmdi input has lost audio
several things could cause that:
1. hdmi cable is no good.
2. receiver and TV are not fully compatible. I noticed few times that philips tvs had problems with denon receivers. Some times you need o unplug hdmi cable and plug it in back to get sound.
3. firmware issue. depends on model of your receiver there could be a software upgrade to resolve the problem.
4. somebody (kids) accidentally pressed some buttons and reassigned video input for that video source (video select button on a remote control), etc. Resetting the receiver usually helps.
5 Receiver (hdmi board is no good) or TV is no good.
so next time when it happens check video source, video input assign then try to swap hdmi cable and TV
Nov 28, 2011 | Denon Audio Players & Recorders
I have an RCA HDTV 52" Rear Projection tv.. do
No they do not have digital tuners inside them. They are meant to be monitors to converter boxes, cable boxes, and satellite television receivers.
Jul 19, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
my truck was in the body shop for 3 month battery was unhooked they had to replace the air bag on the passanger now the radio works the cd player works but the sirius radio part of the radio doesnt what can it be and how can i fix this
I know with satellite TV boxes like DirecTV and Dish Network, if they're "out of the stream" either unhooked from the satellite cable or unplugged for an extended term, they change the card codes a bit and their boxes need a "hit" from them. Basically DTV or Dish just sends down an update for your box / card. I think your satellite radio may have a similar issue. Call Sirius and explain your problem, they should be able to give your receiver a "hit" or an update and if that's the problem, you'll be up and working again.
Mar 14, 2010 | Alpine CDA-9886 Car CD/ MP3 Player
sound cuts out
This sounds to me as an issue not with your AVR but with your cable unit. I have seen this where there is a sample rate issue with the cable boxes. I would try to get another cable box, and see if the issue persists.
Gary
Aug 28, 2008 | Denon AVR-2803 Receiver
i have a sony bravia kdl-26m4000
Cable boxes have notoriously flaky HDMI outputs. I have seen No pic and no sound with their HDMI outputs as well as a host of other problems. You can try getting the cable box replaced; unfortunately I have seen multiple cable box replacements not fix the problem. The best solution is to leave the component cables connected; you're not losing hardly any resolution/picture quality by using the component instead of the HDMI. Solution #2: switch to a satellite provider. I rarely see HDMI problems with satellite boxes
May 28, 2008 | Sony BRAVIA KLV-S40A10 40 in. HD-Ready LCD...
798 people viewed this tip
Top Sansui Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
