Tip & How-To about Exercise & Fitness
TEST PROCEDURE FOR DC MOTOR
V\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} p\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} v\:textbox {display:none;} Remove the M+ M- wires from the drive board. Put multimeter to the 200 VDC setting. Place one probe on the M+ wire. Place the other probe on the M- wire. Spin the motor flywheel with your hand. Normal results: The faster the motor spins, the more voltage is produced. If no voltage is produced, replace the motor.
Exercise & Fitness Logo
spark plug wiring diagram for a 2003 chevy malibu
SPARK PLUG WIRE REPLACEMENT (ENGINE CONTROLS - 3.1L)
Removal Procedure
  1. Turn OFF the ignition.
  2. Notice: Twist the spark plug boot one-half turn in order to release the boot. Pull on the spark plug boot only. Do not pull on the spark plug wire or the wire could be damaged.
  3. Remove the spark plug wires 2, 4, and 6 from the engine left side spark plugs.
  4. Remove the spark plug wires from the retaining clips.
  6. Remove the spark plug wires 1, 3, and 5 from the engine right side spark plugs.
  7. Remove the spark plug wires from the retaining clip.
  9. Remove the spark plug wires from the ignition coils.
  10. Remove the spark plug wires from the engine.
  11. If you are replacing the spark plug wires, transfer any of the following components:
    • Spark plug wire conduit
    • Spark plug wire retaining clips
Installation Procedure
  1. Install the spark plug wires to the engine.
  2. Install the spark plug wires to the ignition coils.
  4. Install the spark plug wires 1, 3, and 5 to the engine right side spark plugs.
  5. Install the spark plug wires to the retaining clip.
  7. Install the spark plug wires 2, 4, and 6 to the engine left side spark plugs.
  8. Install the spark plug wires to the retaining clips.
v\:* { behavior : url(#default#VML); position:absolute; } v\:* { behavior : url(#default#VML); position:absolute; }
Aug 20, 2014 | Vehicle Parts & Accessories
Error message shows "Paper Jam" even there is no paper in the system
Clean oops sensor, check sensor flag & position springs,,..
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);}
Feb 20, 2013 | HP DesignJet 100 Plus InkJet Printer
sony z1 camcorder fails to power up with fully charged batteries
dear try to change the battery ,if still it doesnt work then ...i need nt tell you that ur camcorder is dead ,.. and for that .....
their are circuit protector (commonly known as fuse) in DD board which supplies the power to the VC board ..
and for repairing the DD board to need to take to the service center as their is allot minor soldering work to be done on the board.
Superb Broadcast Equipmentv:* {behavior:url(#default#VML);}o:* {behavior:url(#default#VML);}p:* {behavior:url(#default#VML);}.shape {behavior:url(#default#VML);}v:textbox {display:none;}Slide 1.O {color:#006699; font-size:149%;}a:link {color:#CC99FF !important;}a:active {color:#EBF7FF !important;}a:visited {color:#F2DFFD !important;}
Jun 29, 2009 | Sony Video Cameras
portable dvd player cant read and play disc anymore
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4
8,904 people viewed this tip
Top Exercise & Fitness Experts
Treadmill Repairs...
Tom Chichester
ray gallant
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
