To change the code on a Sentry Safe CSW3607, follow these steps:
Open the safe by entering the current code on the keypad.
Press and hold the "*" button on the keypad for three seconds. This will put the safe in programming mode.
Enter the current code on the keypad, followed by the new code you want to use.
Press the "#" button to save the new code.
Close the safe and test the new code to make sure it works.
It's important to note that the CSW3607 has a factory default code of "0000". If you have not changed the code from this default, you can simply enter the new code you want to use without going through the programming mode.
The latest software version of Nokia 5800 is version 60.0.003.You can do it via OTA (over the air) thru GPRS (mobile service providder's internet gateway) or via wi-fi connection or even via PC suite. OTA via GPRS: 1. type *#0000#2. the current software version will be flashed on your phone's screen3. select option4. select check for updates5. it will ask you to connect via your mobile service provider's connection.5. select yes6. it will give you the current available updates for your phone7. if it's available for your phone, it will be displayed for the latest version for the version 60.0.003's availability varies per region.8. once available, select update then it will be automatically downloaded to your phone then once done phone restarting, you will have the version 60.0.003, you good to go... VIA Wifi: 1. type *#0000#2. the current software version will be flashed on your phone's screen3. select option4. select check for updates5. it will ask you to connect via your wi-fi home network connection5. select yes6. it will give you the current available updates for your phone7. if it's available for your phone, it will be displayed for the latest version for the version 60.0.003's availability varies per region.8. once available, select update then it will be automatically downloaded to your phone then once done phone restarting, you will have the version 60.0.003, you good to go... VIA PC SUITE: Go to this address and follow instructions (make sure that you have available USB cable for your phone for you will need to connect to your pc to do this): www.ovi.com/softwareupdate thanks for choosing fixya.com
insert code :
*#92702689# - takes you to a secret menu where you may find some of the information below: 1. Displays Serial Number. 2. Displays the Month and Year of Manufacture 3. Displays (if there) the date where the phone was purchased (MMYY) 4. Displays the date of the last repair - if found (0000) 5. Shows life timer of phone (time passes since last start)
and
View the firmware version of the phone
Dial using the keypad: * # 0000 # - the version number displayed on the display.
like this example :
V 5.16
22-06-99
NSM-1
V 5.16 - software version
22-06-99 - date
NSM-1 - The hardware (model)
View IMEI
Dial using the keypad: * # 06 # - IMEI number is displayed on the display.
take this: 1- Press Function 2- Press Down button until menu “Change password” displayed -> ENTER 3- " Current password " : Press this Number "726276642" -> Enter 4- “New password” 5- 0000 ENTER 6- EXIT 7- Press DIAL LOCK KEY
Try the last four digits of your phone's number, then 0000, 1234, etc... Did you reset the PIN yourself, or is it the default PIN? If you didn't change it yourself the above mentioned will probably unlock it, if not, you may have to take it into a service providers Corporate location and have a Tech. unlock it. Good luck.
