Tip & How-To about Pioneer VSX-D608 Receiver
My Pioneer displays Overload
Overload is displayed when the amp draw is excessive, and can be caused by different faults.
when Overload is detected, the protection circuit will shut down the unit to prevent further damage.
The first thing to try is hard reset. Shut down the unit for about one hour to drain power completely.
This can fix minor problems that can cause overload, for example electrostatic charge accumulation on internal capacitors.
If that does not fix the problem, then you must find the fault.
Overload can be caused by shorted speakers, wrong impedance speakers, or by a contact on speakers wiring.
Check speakers connection and test different speakers with 6, or better 8 Ohms impedance.
Another test can be done by unplugging all speakers, and reconnecting and testing them one at a time, at a very low volume.
If the speakers are OK, then preamp, shorted input/output connectors, main power supply or faulty output transistors can draw too much amps causing overloading.
In that case it is recommendable contacting Pioneer at the number listed on the owners manual.
Pioneer VSX-D608 Receiver Logo
I am having the push power protector issue with my Sony BVD E4100 home theatre. Removed all the speaker wires and tried, the same is showing in the display. Called Sony service centre , told that need to replace the amp board and will cost around 5000/-. Also called Sony complaint customer care they told to turn the device off for 2 hrs and try ,but no use the problem still exists. Is there any permanent solution for this??
The chances are that there is a fault on the power board. Since the protect circuit is detecting an overload. This might be caused by the main power amp section, transistors or whatever is causing the short.
If you can fault find on electrical equipment then you need to find the faulty parts. Otherwise you will have to pass it to a repair centre. It's unlikely to be the whole board. A visual inspection might reveal burnt or damaged parts! Check any big capacitors for bulges on top.
Jun 01, 2018 | Sony Audio Players & Recorders
NAD M3 power light turns red immediately and PROTECT message displays. Amp keeps functioning but volume control doesn't work up or down.
Hello
Check the connection to speaker with this amp, for any short or any other fault. disconnect the outputs, ie, speakers from the amp, and switch it On, and see the protect display comes or not. If it comes, the fault is internal and the set need service.
Your M3 dual Mono integrated amp, is of high output power and its outputs are protected against any overload or short circuit. If the system detect any among this condition specified above, it will show protect mode display.
Never load this amp, as protection display is there, as it may damage the speaker or its internal power amplifier section circuits, may cause more money to get it repaired. OK.
Jan 23, 2012 | NAD M3 Master Series Integrated...
why does my sub and amp go into protected mode when i turn my headlights on
Hi.
Devices go in protect mode when a fault condition is detected. These include insufficien voltage, excessive load, shorts and contact, overheating.
In your case the problem is usually excessive power draw. A contact in wiring can also cause the problem, but this is far less common.
Use a capacitor fix the excessive power draw from the amp and sub.
See:Capacitors - BOSS AUDIO SYSTEMS
Regards.
Ginko.
Jul 01, 2010 | Sony Xplod XM-1652Z Car Audio Amplifier
Amplifier displays "CUR"
Hello anwbrown,
The "CUR" display means that the amp is drawing excessive current and the protection circuit is activating. Too low impedance or shorted speakers will cause the amp to draw excessive current.
The Alpine V12 is a Class D mono amp with only one set of speaker outputs. All versions, M301, M501, and M1001 are only stable to 2ohms. Assuming that all 6 of your connected subwoofers and speakers are 4ohm and they're all connected in parallel, the amp sees a .67 ohm load, far below it's rated impedance.
When brand new, the amp could probably operate at low to moderate volume levels without drawing excessive current. But as electronic components age, their tolerances change and they become less able to withstand excessive current or mismatched impedances.
I'd get a 4-channel amp and drive the 4" speakers off the front channels and the 6X9's off the rear channels. And just power the subs off the V12 making sure that they are connected to show a minimum load of 2ohms.
Hope this helps.
Jul 27, 2009 | Alpine MRV-F345 Car Audio Amplifier
VSX-D608 Overload and shutdown
No more than two 4 Ohms speakers can be connected to the unit, or you will get overload.
Jun 22, 2009 | Pioneer VSX-D608 Receiver
2,535 people viewed this tip
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
ThaMp3Doctor
ThaMp3Doctor
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
