Tip & How-To about Samsung Tab Tablets & eReaders
Android Tablet Hard Reset Method
If you had forgotten your Pattern lock of your Tablet, you can reset it of your own.
You can recover it through your Gmail account, enter the pattern for 15-20 times. After it you will be asked to enter your Gmail password.
But, if you do not remember Gmail password
then Hard reset will be the Final solution to your question.
Different Hard reset factory wipe methods for Android Tablet Different Hard reset factory wipe methods for Android Tablet
Tablets & eReaders Logo
i got locked out of my kurio
If the tablet is connected to the internet, tap on forgot password or pattern then enter gmail account to receive an email with the correct password/pattern you set.
Below are steps to recover from being locked out. The first is the most extreme. The second is less extreme. And the third is probably the preferred method.
Firs, t the extreme reset. You lose your data but it returns it to factory default condition, i. e. right out of the box.
Kurio Extreme 2 Factory Reset
Secondly, the soft reset.
Kurio How to Perform Soft Reset
Thirdly, a Kurio password reset:
Kurio Password Reset Kurio 4S Kurio 7S Kurio 10S
AX109JC20130709
You do not say what type of password was set and if you have forgotten it or just want to reset from a known password..
If you just want to change your gmail login password
- Go to google.com/accounts on the tablet browser
- Sign in
- "Change Password"
- Go back to the Home Screen on the tablet
- Open the GMail app, clicked on Menu, then Refresh -- you will get a sync error
- Wait for a notification to re-enter your password (a triangle with an exclamation point in the tablet notificaiton bar and/or something in the gmail screen)
- Enter the new password
This simple solution sometimes works:
Turn it off.
Turn back on.
When you get the warning triangle in the notification bar, open the notification.
You will then get a login screen.
Input your new password.
Pattern Lock- Incorrectly enter pattern 5 times (4 or more points each time) . Pop up message will appear Click Next and you will be prompted for goole a/c details or security for pattern lock.
tap forgotten pattern and on next screen enter goole account details. Then next screen allows you to choose a new screen lock option.
Locked with PIN or password _Try Screenlock bypass pro from play store.
The only other solution is a hard reset which is only as a last resort. You need to access Androids Recovery mode. Check your manual. Most devices it is power off then power up holding volume + and power buttons.
Once in this mode use power down button to highlight "wipedata/factory reset option, then use power button to select it.
Vol - button to to scroll and select yes delete all user data option with power button. When device reset select option to reboot now and the device will turn on unlocked but you will have lost your personal data.
Face unlock - you were asked to provide a pattern or PIN backup when you set it. Just bypass and enter PIN or pattern.
Good Luck
2answers
how do i unlock my tablet after ive entered too many pattern attempts, and have forgotten my Username(email) Password?
its brand new and you forgot everything already if you did the google mail password assist then open that if dont know that or didnt do it can try provider for assistance and most lockouts are either 1hr or 24hr
i forgot my lock pattern on my cruz reader
If you are running Android on the Cruz Reader and you have set up your Gmail account on it, then the reset is pretty simple. If you enter the pattern incorrectly several times, and option will come up for resetting a forgotten password. If you select this option, it will ask you for the username and password to the Gmail account that is set up on that device. Hope this helps and good luck!
4answers
I have locked my MID Android Tablet. I have forgotten the pattern, So is there any one who knows how to unlock the pattern?
pls try reset your mid tablet pc, if it can't, maybe you can contact your seller. if you can't contact your seller, you can ask another mid tablet pc seller online help sevier. as: http://www.mcwto.com, they are an mid tablet pc wholesaler.
Top Samsung Tablets & eReaders Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
