Tip & How-To about LG SuperMulti Network Attached Storage N1A1DD1 Network Storage Server
How to remove hard drive
There is a single screw under the sticker on the bottom that says the warranty will be voided if you remove it. Remove that sticker and unscrew that black screw.
Then one of the white panels (the one closest to the actual hard drive) will slide towards the front of the enclosure when you push outward on the two black panels enough to clear the white tabs from the big white panel.
LG SuperMulti Network Attached Storage N1A1DD1 Network Storage Server Logo
directional pad for psp help
You need to take apart the PSP. To do that there are 4 screws in the back of the PSP. WARNING, this WILL void your warranty if you have one. Now, there are 3 screws visible, the last one is in the battery compartment under the batter under the sticker that says something about voiding your warranty if you take this sticker off. Unscrew the last screw and the front should come off nice and easy. Then you can clean and fix your key and screw it back together.
Nov 11, 2011 | Video Game Consoles & Games
my ps3 160gb will need assistance how can i open it???
A PS3 can be opened rather easily, but if your PS3 is newer, or still has a warranty on it, I wouldn't open the case. If you're unsure of whether you still have a warranty on it, you can call 1-800-345-7669 and they will give you instructions. If you open your case, you WILL void the warranty. That being said, here goes:
1. Locate the side of the PS3 with the HDD symbol on it(The left side of the PS3). Above the HDD symbol, there is a sticker that covers a plastic cover. Removing this sticker will void any warranty still on the PS3.
2. Peel off the sticker and gently pry the plastic cover out. There is a recessed area with a screw at the bottom, use a small screwdriver to unscrew it.
3. The plastic cover on top of the PS3 is now loose, and you can slide the plastic cover towards the left side of the PS3(where you just removed the sticker) and lift it off.
4. There are 8 screws holding a second plastic cover down. Unscrew them with a Phillips head screwdriver, and set them aside. Lift the cover straight off, and set aside. You have now opened your PS3, and have access to the Blu-Ray player and other internals.
Good Luck!
Jul 06, 2011 | Sony Playstation 3 (PS3) Console
I can not get the bin out of the shredder, i believe it is off track and completly full with shreds coming out. I want to know can I take it apart somehow and fix it myself (You know the screws on the bottom I unscrewed them and tied to open the sides gently but it does not seem to put the bin back in track)
Dont wont to do if shredder is under warranty. If not, you will usually see a sticker staying that if you remove this sticker you warranty is voided. There is a screw that holds the top on. If you take the sticker off your warrranty is voided so beware.
Apr 14, 2011 | Aurora Electronics AS1219CD (CrossCut)...
have paper jammed in my shredder is there anyway we can take it apart
YOu can remove the screw for the bottom, but beware if you do this you will void any and all warranty. There will be a sticker on the bottom that is covering a screw that is usually missed and says if this is removed warranty is void. So make sure before you take it apart that you have no more warranty
Feb 20, 2011 | Aurora Electronics Office Equipment &...
My PS3 does not turn on ,..the yellow and red light blinks
You've got the YLOD.
Here's a DIY tutorial on how to fix but I recommend getting it fixed by Sony direct!
Oct 14, 2010 | Sony Playstation 3 (PS3) Console
2,819 people viewed this tip
Top LG Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
