Tip & How-To about Samsung LA32A450 32 in. HD-Ready LCD TV
SERVCIE MODE
Panel Check
You have to check Panel Maker Because of different adjustments as follows. First of all, Check the label rating!
1) Label Rating File
- LCD PANEL MARK
A:ACER(AUO) S : SEC C : CMO
* If not printed you could consider S(sec) panel mark.
Method of Color Calibration (AV)
1) Apply the NTSC Lattice (N0. 3) pattern signal to the AV IN 1 port
2) Press the Source key to switch to "AV1" mode
3) Enter Service mode
4) Select the "Calibration" menu
5) Select the "AV Calibration" menu.
6) In "AV Calibration Off" status, press the " RIGHT ARROW" key to perform Calibration.
7) When Calibration is complete, it returns to the high-level menu.
8) You can see the change of the "AV Calibration" status from Failure to Success.
Method of Color Calibration (Component)
1) Apply the 720p Lattice (N0. 6) pattern signal to the Component IN 1 port
2) Press the Source key to switch to "Component1" mode
5) Select the "Comp Calibration" menu.
6) In "Comp Calibration Off" status, press the "RIGHT ARROW" key to perform Calibration.
8) You can see the change of the "Comp Calibration" status from Failure to Success.
Method of Color Calibration (PC)
1) Apply the VESA XGA Lattice (N0. 21) pattern signal to the PC IN port
2) Press the Source key to switch to "PC" mode
5) Select the "PC Calibration" menu.
6) In "PC Calibration Off" status, press the "RIGHT ARROW" key to perform Calibration.
8) You can see the change of the "PC Calibration" status from Failure to Success.
Method of Color Calibration (HDMI)
1) Apply the 720p Lattice (N0. 6) pattern signal to the HDMI1/DVI IN port
2) Press the Source key to switch to "HDMI1" mode
5) Select the "HDMI Calibration" menu.
6) In "HDMI Calibration Off" status, press the "RIGHT ARROW" key to perform Calibration.
8) You can see the change of the "HDMI Calibration" status from Failure to Success.
FOR MORE DETAILS CHE THE FOLLOWING LINK
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
USE SEARCH TAB FIND MODELS OR USE DROP DOWN MENU
Samsung LA32A450 32 in. HD-Ready LCD TV Logo
Can someone please recommend a personal label maker?
Try the Brother Personal Electronic Handheld Labeler. It is the highest rated labeler on Amazon.
http://www.amazon.com/Brother-Personal-Electronic-Handheld-Metallic/dp/B004H1S6FY/ref=sr_1_1?s=office-products&ie=UTF8&qid=1361353584&sr=1-1&keywords=PERSONAL+LABEL+MAKER
Feb 20, 2013 | Office Equipment & Supplies
How do i adjust the sensitivity of my touch pad for my Toshiba laptop PSLB8U-05202F
1.Turn on the computer and log into Windows as normal. Open the "Start" menu and click on the option labeled "Control Panel."
2.Double-click on the icon labeled "Mouse.". The "Mouse Properties" window will open. Navigate to the tab labeled "Device Settings." Click on the button labeled "Settings." A window labeled "Properties" will appear.
3.Examine the left panel of the "Properties" window and expand the option labeled "Sensitivity." Click on the option labeled "Touch Sensitivity."
4.Reduce the touch sensitivity setting by moving the slider to the right, towards the "Heavy Touch" label. Experiment with different levels of sensitivity until you find one suited to your needs.
5.Click on the button labeled "OK" to close the "Properties" window; repeat with the "Mouse" control panel. Your new touchpad sensitivity settings are now saved.
Sep 14, 2011 | Toshiba Satellite L305-S5908 Notebook
Labelmaker program will not print image in right place
This can drive you nuts! :)
It sounds like you need to adjust the label orientation with the label maker software first. THEN, use regular paper to test your adjustments. Take the print out from a regular piece of paper and overlay it on the label paper. Hold it up to a light and see how the labels align. Re-adjust if you need to. You won't waste your label paper that way.
Also check the settings on the printer as well, making sure you have selected the correct paper or tray (if equipped).
Apr 07, 2009 | HP Deskjet F340 All-In-One Printer
Zebra S600 Tear position adjustment won't stay put
To be sure we're talking about the same thing, you pressed MODE twice, then used UP and DOWN to align it, right?
Have you checked your Printer Preferences and Printer Defaults? Could be a label size setting somewhere. Preferences follow the Windows user, Defaults follow the print device.
Try to restore factory settings if all else fails. I have to do this quite often. Best to start with a clean slate.
Here's the manual if you need it:
http://tinyurl.com/yb2rpd4
Hope this helps! If so, please leave a rating!
Nov 13, 2008 | Zebra Stripe S600 Thermal Label Printer
2,312 people viewed this tip
Jerry Greenberg
Jerry Greenberg
Ekse
