Tip & How-To about Samsung Tab Tablets & eReaders
How to make my tablet run faster
The cache on your Samsung tablet is designed to make things run smoothly. But over time, it can become bloated and cause slowdown. Clear out the cache of individual apps in the App Menu or click Settings > Storage > Cached data to clean all app caches with one tap.
Speed up a slow Samsung tablet - Which Computing Helpdesk
https://computing.which.co.uk/hc/en-gb/.../209878085-Speed-up-a-slow-Samsung-tablet
Turn off or reduce animations. You can make your Android device feel snappier by reducing or turning off some of animations. You'll need to enable Developer options in order to do this. Go to Settings > About phone and scroll down to the System section to look for Build number.6 Aug 201411 tricks to make your Android run faster - Android Authority.
tablet running really slow Google Search
Tablets & eReaders Logo
My tablet has started running really slow and sometimes freezes up. How can I fix?
hi Debbie.
How do I make my tablet run faster?Turn off or reduce animations. You can make your Android device feel snappier by reducing or turning off some of animations. You'll need to enable Developer options in order to do this. Go to Settings > About phone and scroll down to the System section to look for Build number.6 Aug 201411 tricks to make your Android run faster - Android Authorityhttps://www.androidauthority.com/11-tricks-make-android-run-faster-414542/Search for: How do I make my tablet run faster?
or go to this link should help you out some more.
Nov 26, 2017 | Tablets & eReaders
Movies are not playing smoothly on my Tablet (eg sbs on demand,) they seem to be jerking all over & then stop?
Clear memory, clear browser cache, don't have a ton of other tabs open in your browser while trying to watch movies. This is doubly so if you are using Google browser, as it is a serious memory hog. You colud also buy additional memory for your tablet (maybe).
Nov 17, 2017 | Tablets & eReaders
What do you do when Alcatel one touch tablet is stuck on sprint yellow screen and won't do anything
I'm not familiar with that specific tablet, but all Android devices have a way to enter a recovery mode menu that allow you to clear the cache or do a full factory reset. First, try the 'clear cache' option. If that doesn't work, you'll have to do a full factory reset (and you'll lose all of your apps and data).
  • Turn off your tablet all the way.
  • Then press and hold Volume Up + Power button until you see the Recovery Mode menu.
  • From menu on your screen choose option "clear cache" or "delete cache" by using Volume buttons to scroll and Power button to confirm.
  • Try to restart your tablet. If it still doesn't work, then do the same thing again, but this time...
  • From menu on your screen choose option "wipe data/factory reset" by using Volume buttons to scroll and Power button to confirm.
  • After that select option "Yes -- delete all user data", and confirm that.
May 04, 2016 | Tablets & eReaders
how to get more storage space
if your settings do not point to the micro sd card then you will be using up your space on the tablet, you need to go into your settings and make sure that you movies, video's, photos, and anyother items that can be moved to the micro sd card are pointing to that card as a backup , install, and saves also try clearing your cache's both on the tablet and your internet browser cache.
I have a kindle fire and i have to do this in order to keep it running smooth, also having cloud helps. so this is what I suggest. and Good Luck
Dec 07, 2014 | Samsung 8.4 Galaxy Tab S 16GB Bronze
354 people viewed this tip
Top Samsung Tablets & eReaders Experts
Eric Rotmil
Eric Rotmil
Jerry Greenberg
Jerry Greenberg
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
