Tip & How-To about Apple iPhone Smartphone
How to fix iPhone 8/8 Plus screen black issue?
Phone screen black is a common issue with iPhone, the basic case it that phone can't turn on or phone is running but the screen is black. Here we will talk about how to fix iPhone 8/8 Plus black screen issue.
How can fix iPhone 8 8 Plus screen black issue
Apple iPhone Smartphone Logo
my fake iphone 5 keeps showing that whitte apple logo and then the screen turns black and it keep repeating
Hi, This is probably too late but I really hope this can help you or others.
Firstly, we need to know what cause the Red Screen Issue:
A. Your iPhone Device Has A Hardware Problem
B. Your iPhone device has been jailbroken
C. Your iPhone device has a failed software update
Secondly, Here are some common solutions to fix Red Screen of ***** Issue:
A. Perform A Soft Restart on Your iPhone Device
B. Perform A Force Restart on Your iPhone Device
C. Restore Your iPhone's Default Factory Settings
D. Bring Your iPhone into DFU Mode
E. Update Your iPhone to The Latest Software
Thirdly, If the common solutions could not solve your problem. You can try an data recovery software - FoneDog toolkit.
Step 1: Download, install and launch FoneDog Toolkit.
Step 2: Proceed to System Recovery.
Step 3: Review Reminders before The Recovery Process.
Step 4: Download The Firmware.
Step 5: Downloading and Repairing
Step 6: Repair is Complete
More Information you can see: Ways to Fix Red Screen Issue in iPhone Device
The red screen issue in iPhone devices is truly a bothering issue to have since it can stop you from being productive in using the phone or making it fully functional. Through the common solutions we have shared above for fixing such issue, as well as the help of FoneDog toolkit, we hope that the red screen issue in your iPhone has now been fixed.
Hope it can help you!
iOS System Recovery Guide How to Fix with Various iOS System Issues
Jan 05, 2015 | Apple Cell Phones
my touchscreen android phone hasn't turn back on for 2 weeks,is there another way of fixing it without a repair man
As you probably already know, there are almost an endless number of ways that your iPhone can come into contact with moisture. For example, recently, I had my iPhone 4 in my back pocket when it accidentally slipped out when I had my pants down using the toilet. Don't ask ! There is some good news however, and that is in most cases, a wet iPhone repair can be made without your having to buy a new one. Yes, dropped iphone in toilet is very, very common.
The terrific news is that all models of iPhones can usually be repaired after sustaining water damage, but this must be evaluated on a case by case basis (in my case, my iPhone could be repaired for a nominal charge).
Fortunately, iPhones consist of parts that can be readily swapped out for good ones. If, however, your iPhone has been fully submerged in water or other wet substances, chances are that the logic board in your iPhone has been exposed to moisture and corrosion has begun to take place.
If the logic board is damaged, the cost of the repair can get quite pricey, especially if other parts also need to be replaced on your iPhone. The logic board is the main circuit board in the iPhone that runs the operating system and stores all data on the iPhone. The logic board is not typically too expensive to replace on its own, however, coupled with other parts that might also need to be replaced, the cost for repair may run you a pretty penny..
Nov 01, 2012 | Cell Phones
I dropped my iPhone 4 and now the screen is just black, like when you turn it off. I can still hear when I get a msg but thats all, what can I do without taking it to a shop?
Reasons for Black Screen of ***** and How to Fix it
Jun 02, 2012 | Apple iPhone 4 Black Smartphone
I am having serious problems with dropped calls on my iphone
Unfortunately, this has plagued the AT&T iPhone since the original model came out. It's most likely a dead zone causing the issue (I have the sameissue from time to time). You can also get a Micro Cell from AT&T, it's basically just an access point that allows you to pick up a cellular signal at home or work (where ever you set it up).
To eliminate any hardware issues, make sure you're on the latest build of the OS (4.3.3 for the AT&T iPhone 4) - I noticed you're still on 4.3.2. If you don't have a case, I suggest the Apple bumper or any case that covers the metal bezel on your phone, that will help as well.
Also, you can "reboot" your phone. To do this, hold down the metal sleep button on the upper-right corner of your phone until the "slide to power off" slider is displayed, then power off the phone. Wait a few minutes and turn it back on.
Hope this helps!
Jun 23, 2011 | Cell Phones
410 people viewed this tip
Top Apple Cell Phones Experts
Ekse
Marvin
Marvin
Travis
Travis
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
