Tip & How-To about Tefal Kitchen Appliances - Others
How to Fix a Vegetable Steamer
Fixing a clogged up veg steamer, see video.
Kitchen Appliances - Others Logo
mw Daewoo fridge freezer FRS-20321BE is leaking water copiously from the refrigerator I cannot see any source for this but puddles form and flow internally under the veg box. Help!
All depends on how much water is collecting. A lot of water indicated a leak from the ice maker. A small amount and it's probably a clogged condensate drain. Here's a YouTube video on a different brand showing a clogged drain, your may be similar (or not), but it might give you an idea as to where to look. Refrigerator dripping water inside FIX
Mar 07, 2016 | Daewoo Refrigerators
What is the rack for?
Steaming. Fill the pan to just below the rack level and put veg or food on top of rack. Switch on. If you are steaming buns or sticky food lay a sheet of greaseproof paper or cabbage leaf on the rack first to stop it sticking.
Mar 14, 2015 | Kitchen Appliances - Others
need instructions on cooking times for steaming veg
On a 1000 watt oven, I find 7min about right for most vegetables. Those which need more cooking may require 10min or more.
Apr 14, 2013 | Pyrex Pyroflam Steamer Set, 2L
steamer switches on off on during cooking process
Hi Markus, did you manage to solve your problem somehow? I experience the same (with the same steamer).Thanks.Tomas
tondrejcak@yahoo.com
Mar 31, 2010 | Kitchen Appliances - Others
Rice is not steaming properly...what am I doing wrong?
It may be clogged with calcium, this video of a similar Tefal steam cuisine 600, vegetable steamer, and me fixing it, may help
Jan 10, 2008 | Tefal 61621 Steam Cuisine 2-Cup Rice...
150 people viewed this tip
Top Tefal Kitchen Appliances - Others Experts
Gerry Harvey
Gerry Harvey
Andrew Taylor
Andrew Taylor
Gil Shultz
Are you a Tefal Kitchen Appliances - Other Expert? Answer questions, earn points and help others
