Tip & How-To about Cooking
Hard Boiled Eggs...Fire and Forget
If you have a electric kettle with an auto shutoff making hard boiled eggs will never be easier!
Fill the kettle 1/2 way with cold water and add 6 or less small-medium eggs and then turn on the kettle and just walk away! When you're finished whatever you had to do you can come back 1/2 hour later or more and your eggs will be finished, just like that!
Cooking Logo
Kettle not heating up water but electricity is reaching the kettle
How to fix an electric kettle part 1 - YouTube
? 4:51
https://www.youtube.com/watch?v=P4dcq5p0FyU
Apr 15, 2013 - Uploaded by Anthony Findlay
how to troubleshoot and fix an electric kettle. ... I am using akettle had small problem the switch was not working so I have tried to fix it but I am ...
HOW TO REPAIR ELECTRIC KETTLE - Fix Your Electronics ...
electronicsolutn.blogspot.com/2012/10/how-to-repair-electric-kettles.html
Oct 25, 2012 - Electric Kettle is a kitchen appliance that contains a heating properties used for boiling water, cook food etc. It is made up of a metal or plastic ...
electric kettle light but not heating Questions & Answers - Fixya
Dec 08, 2015 | Hamilton Beach 40996 Programmable 1.7...
how do i get rid of a taste when making a brew
Water and white vinegar will descale your kettle which may be causing the taste. Follow these instructions:
http://www.topcleaningsecrets.com/house/kitchen/how-to-clean-an-electric-kettle.html
Jan 19, 2015 | Kitchen Appliances - Others
THE AMOUNT OF WATER YOU USE IN THE EGG GENIE IS UNCLEAR
Decide if you want soft, medium or hard boiled.
pick the correct scale, and fill to the the number of eggs you have in the cooker, 1 requires more water than 7 because the eggs sit partly in the water. The "timer" is based upon the evaporation of the water over time, the fewer eggs, the less displacement in the water pool, but also easier for water vapor to escape.
Feb 12, 2012 | Emson Home Security
my friend bought me a hyundai egg cooker(plu 247959) but the instructions only tell you how to soft boil 2 eggs or hard boil 3! and no instructions of other amounts of eggs or how much water to use or how to use the poaching facility!!!
Ignore the instruction manual. Instead look at the measuring cup that comes with your Hyundai PLU 247959 (produced and sold under license by Poundstretcher).
On the side of the measuring cup, you can see three clusters of marks:1. 25 to 40 ml for soft-boiled eggs (symbol of egg with two horizontal lines)2. 45 to 60 ml for medium boiled eggs (symbol of egg with one horizontal line)3. 65 to 80 ml for hard boiled eggs (symbol of egg)
Egg boilers are based on the principle that the larger the volume to be heated is, the less water is required. In other words, you will need to add less water for boiling seven eggs, and more water for boiling one or two eggs.
Which means that for seven eggs to soft boil, add 25 ml; and for one egg to soft boil, add 40 ml. If you look at the markings, you'll notice that on the vertical line between 40 and 25 ml, there are seven equidistant horizontal lines, each showing the amount of water required for the various quantities of eggs.
One egg = fill with water up to the 40 ml markTwo eggs = fill up to the mark below the 40 ml markThree eggs = fill up to the second mark below the 40 ml markFour eggs = fill up to the third mark below the 40 ml mark etc, untilSeven eggs = fill up to the 25 ml mark
Medium boiled and hard boiled eggs are measured in similar ways. Works every time for me. Nice little egg boiler, by the way.
Oct 09, 2011 | Back to Basics TEM-500 Egg & Muffin...
instruction manual is in french ,need it in english
Egg Genie cooks up to 7 eggs at once-with no guesswork, no underdone or overdone eggs.
Just add the indicated amount of water.
Press "on"and your work is done.
The Egg Genie automatically steams eggs and alerts you when they're ready.
Here are the amounts in teaspoons of water:
4 tsp = 6 soft boiled eggs
5 tsp = 5 soft boiled eggs
6 tsp = 3 soft boiled eggs
7 tsp = 1 soft or 7 med
8 tsp = 6 med boiled eggs
9 tsp = 5 med boiled eggs
10 tsp = 3 med boiled eggs
11 tsp = 2 med boiled eggs
12 tsp = 1 med boiled egg
14 tsp = 7 hard boiled eggs
15 tsp = 6 hard boiled eggs
17 tsp = 5 hard boiled eggs
18 tsp = 4 hard boiled eggs
20 tsp = 3 hard boiled eggs
21 tsp = 2 hard boiled eggs
23 tsp = 1 hard boiled egg
May 22, 2011 | Emson EggGenie Egg Genie Electric Egg...
172 people viewed this tip
Top Cooking Experts
Tom Chichester
ray gallant
Clyde Hanson
Are you a Cooking Expert? Answer questions, earn points and help others
