Tip & How-To about Ubisoft Rocksmith
Check the battery in the guitar. May be dead.
From Ubisoft...
Can you please try to restore the PS4 database and see if that fixes the issue for you? It's similar to a computer disk defragmenter and will not affect your save data.
check the battery
1) Turn off the PS4.
2) Once the PS4 is off, press and hold the power button until the PS4 beeps twice (this may take up to 10 seconds)
3) Connect the DualShock controller with a USB cable.
4) Once connected, press the PS button on the controller. You should now see the Safe Mode options on the PS4.
5) Select option "5. Rebuild Database" and press X.
6) "The database will be rebuilt, it might take a few hours to rebuild the database" will show on the screen, press "OK"
7) Allow the database to rebuild. Afterwards, the console will return to the sign-in screen.
Tried it and it worked like a charm can now hear my guitar. And the "rebuild database" takes about 10-15 mins to complete. And all previous data in the PS4 is still there it's more of a disc defragmentation. Hope this helps
If you are experiencing this ce-34878-0 error code, please close the application and then install the latest system software and game patch. If the error occurs again, initialise the PS4 system after back-up of the save data and please also submit any crash reports after re-booting your console when the error occurs. Sure the "solution" isn't exactly helpful for those that have already lost their save file, but it's good to have something to refer to when the error hits. Until Sony patches the PS4 for this error, this is probably as close to a fix as we'll get.
