Tip & How-To about Miscellaneous
DIY: How to repair rotten door jamb
I have found that the back door of my garage had a rotten door jamb. I thought I had bad luck but later found out that it is not uncommon. I had searched YouTube and got some tips how to fix it by myself. Here is what I have done. Hope it can help others who have similar problem.
Miscellaneous Logo
i have a chamberlain 5580 operator it sounds like motors jambed
If the motor is stuck in the open position the trolley may be jammed against a bolt just in front of the motor unit. If so, loosen the chain enough that the tension is taken off the trolley and then run the opener until the door closes. While the door is closed locate the 'up limit' control on the side of the motor unit. Turn this control in the opposite direction of the arrow printed on the cover and then tighten the chain.
If the door is not in the open position you may have a bad start capacitor.
Jun 17, 2010 | Sears Craftsman LiftMaster Chamberlain...
Replacing a Craftsman wired garage entry keypad.
Yep it a snap in piece. Look closely for a why to remove.
Dec 24, 2009 | Sears Craftsman LiftMaster Chamberlain...
no power windows door locks interior lights or key chimes
try checking the pin switches in the door jambs if you have no power to these items with the door open i would lean toward the pin switches being stuck or bad ground or broken not an uncommon problem
Jul 14, 2009 | 2000 Pontiac Montana
Automatic Doors
I found out that the auto sliding doors are just like garage doors.... need lubed, connectors in door jamb cleaned and sprayed with silicone lube and sometimes an ajustment for tension- dealer item.... I took mine to a dealer and drove out 30 min later.... hope this helps.
Sep 13, 2008 | 2003 Ford Windstar
108 people viewed this tip
Top Miscellaneous Experts
Rachael Newton
Rachael Newton
Level 1 Expert
Roger Goldberger
Roger Goldberger
Level 1 Expert
Philippe Dekyvere
Are you a Miscellaneous Expert? Answer questions, earn points and help others
