Tip & How-To about Refrigerators
How to Defrost Refrigerator Defrost Timer Problem
This is intended as a guide to defrosting a refrigerator that has the freezer on the top. Side by sides and bottom freezers may be similar but will require some different procedures to remove covers to get at the defrost coils.
If your refrigerator is not cooling but your freezer is still working then you most likely have a problem with Ice buildup. Sometimes the ice will start to form inside the refrigerator on the bottom of the freezer compartment, even though the refrigerator section is not staying cool.
  1. Empty out the freezer section so that you can remove the bottom panel that covers the evaporator coils. Side by side refrigerators often have the access panel in the back of the freezer.
  2. Use a hair dryer or fan to speed up the melting of the ice. Towels will be needed to soak up the water. A wet/dry shop vac and a hair dryer work the best. Melt with one and collect the water with the other.
  3. Take the couple of screws that hold the defrost coil loose and remove the heater. With an Ohm meter check the resistance of the coil. If the coil is bad you will get either and open or shorted circuit. If you get a good consistent resistance then it is okay.
  4. If your heater coil is good and the fan/blower is working then you probably need to replace the defrost timer or advanced defrost control board, whichever is in your unit.
Replace all pieces and wires to their original positions and then restart the refrigerator. It may take a bit for everything to cool back down, especially in warm weather. Now with everything working properly you should be trouble free again.
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
http://www.fixya.com/support/r4326839-refrigerator_maintenance_tips
http://www.fixya.com/support/r4327013-refrigerator_efficiency
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r4326731-new_refrigerator_size_or_refrigerator
Refrigerators Logo
Freezer does not defrost automaticly, its full of ice??
Take care in solving the problem....
Sep 16, 2011 | Whirlpool GB2SHDXP Bottom Freezer...
i would like to defrost it manually
Hope this help in solving the problem.....
May 10, 2011 | KitchenAid KSRT25CRSS Stainless Steel Side...
I need to defrost my sub-zero 650. Can you give directions?
This is intended as a guide to defrosting a refrigerator. Side by sides and bottom freezers may be similar but will require some different procedures to remove covers to get at the defrost coils.
Good luck
Aug 08, 2010 | Sub-Zero 650 / O Bottom Freezer...
side by side frig/freezer. Freezer auto defrost
Here is a tip that will tell you where the water is coming from and how to fix it. The drain hole has froze shut and the water from the defrost will not drain out.
Water Running in Refrigerator from Freezer
heatman101
Jul 03, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
57,143 people viewed this tip
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
