Tip & How-To about Dishwashers
Dishwasher Problems The Heating Element not Working
If you have determined that the heating element has gone bad in your dishwasher then you may be wondering if you can easily replace it. Actually for many dishwashers the replacement is not that hard. The most important part is that you turn off all power before attempting to do any work!
The heating element is located in the bottom of the dishwasher tub. It will be submersed in the water when the dishwasher is running. To find it, look for a thin circular tube in the bottom of the dishwasher tub. Some dishwasher will have a cover over it. To get to the heating element the racks will need to be removed from the dishwasher and the cover, if there is one will have to be removed.
To replace the element you will have to remove the front kick plate of the dishwasher. A few screws will hold it in place and they are easily removed. Once you are underneath the tub you can locate the terminal ends of the heating element. Make the wires do you know which one goes where to put them back properly. Then pull the wires from the ends of the heating element. Make sure that you are pulling on the terminal connector and not just the wire to remove them.
Once you have the wires removed from the ends of the element, then look for the lock nuts up against the bottom of the tub that holds the element in place.
With a small adjustable wrench or a pliers you can loosen the locknuts. When the nuts are off of the ends of the dishwasher heating element you can then reach into the tub of the dishwasher and gently work the element loose and pull it up and out.
Place the new element into the holes and then securely fasten the new heating element in place with the lock nuts. Use a wrench or pliers to snuggly tighten the nuts. Replace the wires and the kick plate. Replace the element cover if there is one, the racks, and you are ready to roll. Turn the power back on and try it out!
http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not
http://www.fixya.com/support/r4225828-dishwasher_repair_problem_detergent_cup
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
http://www.fixya.com/support/r4319937-dishwasher_maintenance
Dishwashers Logo
dish washer not advancing to the next cycle
This is usually caused by the heating circuit not heating the water. And most of the time, this is NOT caused by a bad heating element, but instead, by a bad controller. A solder connection to the heater relay has gone bad. You can see this easy enough if you take the control module apart. (Depending on the model, the controller is located EITHER in the door, or else on the bottom right-side of the DW.) It is possible to re-solder this connection and get your dishwasher working again, but this is only a temporary solution because the problem is actually in the relay - the contacts have gotten pitted, causing resistance which causes heat which travels down the leg of the relay, causing the solder to melt. The correct solution is to either replace that relay or the complete control module.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Mar 23, 2015 | Bosch Dishwashers
heating problem on dishwasher
Your dishwasher has an electrical heating element that helps to dry the dishes. If the element is burned out, the dishes won't dry properly, and you need to replace the element. To determine if the heating element is burned out, watch the part testing video at the bottom of this page.
Thanks
Apr 01, 2012 | Whirlpool ADP 8900 Dishwasher
AEG Favorit Integrated Dishwasher failing to heat the water. has the element gone? and how do you get at it?
Check your heating element..
A bad heating element causes many problems in dishwashers...
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Mar 23, 2011 | AEG 23 in. Favorit 50750Vi Built-in...
Hi, heating element gone I assume. It works well but does not heat up anymore.
heatman101
Asker
Mar 16, 2011 | Whirlpool 24 in. ADG7540 Built-in...
30,110 people viewed this tip
Top Dishwashers Experts
Marvin
Marvin
