Tip & How-To about Electrical Supplies
A class suit was filed and then later on won against Maytag in 2004 due to the high failure rate of the wax motor used in the door lock mechanism of their Neptune Front Load Washers. The wax motor is used to activate the door lock switch by extending its shaft when a voltage from the machine control is applied across its terminals. Its failure then leads to the breaking down of components in the expensive machine control board. This is the fact that angered the customers which lead to the filing of the class suit.
Electrical Supplies Logo
MAH3000AWW
Many of the (early) Maytag Neptune washers had more than their share of problems. So much so, a class action suit was brought against Maytag; and they paid for repairs, replaced washers or provided credits toward new washers. Many of the problems were tied to the control board and "wax motor" door latch mechanism. Maytag charged $300 - $400 and up to replace the entire control board - when the parts on the board can be easily replaced for several dollars.
Anyway, you didn't include the nature of the problem you're having, so it's hard to provide any direction. It is normal for the board to become darker near resistors - but not burnt. Most problems are burnt resistors, triac and transistors - and of course, in my case - the "wax motor" that was responsible for the whole problem in the first place. It reported that the door wasn't locked - so high speed spin never took place. Clothes were wet and took a long time to dry as a result.
Provide as much detail as you can for the best answers. What does it do? what doesn't it do? strange noises? Has it slowly been getting worse? Does it smell? Do you use regular or HD detergent? I know some questions sound crazy - but knowing the answers to them does help!
Dec 26, 2012 | Maytag Washing Machines
Neptune Washing Machine (MLE200AWW) spins but water is not pumped all the way out. I can hear it slosh in the drum if I spin the drum manually.
Hi, the sloshing sound is normal because of the balance ring which has liquid in it...
I would be concerned about your door latch wax motor ( part # 12002535) though... See Neptune Help for more information about replacing the faulty wax motor with brown colored actuator tip before it damages your machine control board. When the wax motor shorts out it will blow the Q6 triac and then the R11 resistor will burn and your door probably won't lock anymore as indicated by the door locked light not coming on. The next thing you will notice is that your clothes will be soaking wet after the wash cycle because the spin cycle will not work if the door does not lock...
Your machine control board is located above the dryer on the right side.
Every Maytag Neptune front loader with a timer knob (non digital) has a wax motor and all of them shipped with faulty one except the later 2000 series stacker models. You should proactively replace the wax motor with the new design (with black tip) to prevent the Q6 R11 failure on the control board. If you're too late you can try the STAGE 1 repair kit at the same site above.
To inspect your door latch wax motor on the stackers you:
? Unplug machine
? Remove the (2) screws holding center panel and remove panel
? Remove the (1) center screw holding the top panel located inside compartment above washer
? Remove the top panel to expose the door latch assembly
I hope this helps you.
Apr 25, 2011 | Maytag Neptune MLE2000A Front Load Stacked...
my maytag MLE2000AYW will not lock, how hard is it to replace or fix?
  • Unplug machine
  • Remove the (2) screws holding center panel and remove panel
  • Remove the (1) center screw holding the top panel located inside compartment above washer
  • Remove the top panel to expose the door latch assembly
Mar 27, 2011 | Maytag Neptune MLE2000A Front Load Stacked...
1,049 people viewed this tip
Top Electrical Supplies Experts
Gene Haynes
Marvin
Marvin
Are you an Electrical Supply Expert? Answer questions, earn points and help others
