Tip & How-To about Televison & Video
Lock and Unlock most TV's
Http://www.ecoustics.com/tl/17973/
Polaroid:
Having trouble with setting your Parental Controls (V-Chip)?
The factory preset password is 0000. This password must be used first before setting your own personal password. It is recommended that you keep your personal password in a safe place and away from children. In the event you loose your personal password the master password is 8202. The master password overrides all passwords. The master password can't be changed and should be kept in a safe place away from children.
0000, 1078, 1111, 3808, 5050, 8202.
Mitsubishi LCD TV:
Bypassing the V-Chip Lock After you set the lock, you need your passcode to view
a V-Chip locked program, view the locked TV, cancel
the lock, or enter the V-Chip lock menus.
If you forget your passcode, you can view the locked
TV without entering your passcode. When your
password is requested, press the number 9 and QV
buttons on the remote TV control at the same time.
This process temporarily unlocks the TV.
When entering the V-Chip Lock menu, this process
deletes your old passcode and prompts you to enter a
new passcode.
AOC: 0,0,0,0
LG: 7,7,7,7
PHILIPS: 0,7,1,1
SONY: 4,3,5,7
VIZIO: 0000, 2489, 5351, 8202, 8205, 8206
Emerson/Sylvania/Funia: 0000
NOTES from Emerson/Sylvania/Funai:
1.Make sure to enter the exact same new password in the
"Confirm Password" space as one in the space. If they are
different, the space is cleared for reentering.
2. Your password will be erased and return to the default(0000) when a power failure occurs or this TV has been
unplugged for more than 10 seconds. If you forget the password,
unplug the power cord for more than 10 seconds to
restore the password to 0000.
Sharp TV:
Sharp LCD TV Clearing the secret number using the remote buttons and the TV's buttons.
If you forgot the secret number, clear the secret number using the following procedure:
1) Press MENU, and the MENU screen displays.
2) Press Left/Right arrow buttons to select 'SETUP'
3) Press UP/DOWN arrow buttons to select 'EZ setup', 'CH setup', 'Parental CTRL' or RESET, and the SECRETNUMBER INPUTSCREEN DISPLAYS.
Press and Hold both CH UP and VOL+ ON THE TV SIMULTANEOUSLY until the message appears on the screen. The SCECRET NUMBER IS ****.
Televison & Video Logo
bush freeview recorder bu102zrh50 factory reset ive forgot my parental pin no its not 0000
Well according to the manual here
http://www.bushaustralia.com.au/wp-content/uploads/2014/03/BVR501FV.pdf
it should an option in settings called factory reset. You will LOOSE all your settings if you do that though.
Dec 02, 2014 | Bush Televison & Video
my television has a parental lock on it when i turn it on
Setting your TV to factory defaults should clear the password.
Don't know what model TV you have but you can see if it's listed on this webpage and the follow the instructions there:
http://www.ecoustics.com/tl/17973/
Mar 15, 2011 | Televison & Video
My tv has a forgotten password on it to block certain channels. How do I reset it or get it off?
I believe Protron is an RCA subsidiary, so an RCA factory reset procedure may work for you. Try the following:
RCA TV:Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method until you find one that works:
  1. Hold down MENU on the remote and VOLUME DOWN on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds.
  4. Hold down GO BACK on the remote and MENU on the front of the TV at the same time for at least 4 seconds.
  5. Hold down EJECT on the front of the TV and the MENU button on the remote at the same time for at least 4 seconds.
Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Sinotec:
If you have the original remote (RC-A07) for Sinotec tv, then press and hold down the Music button for about 10 seconds.
Mar 14, 2011 | Protron PLTV-32 Television
How to take off child proof lock?
try 0000???
Parental Menu Options
1. Press the MENU and VOL+/VOL- button
2. Press CH+/CH- button to select PASSWORD .
3. Then input the password 0000. It will bring parental menu display on the
screen.
The "Default Password" preset by the manufacturer is
"0000" . If you want to change the preset password to your own password, just
choose any four digits that can be easily remembered and set. Once you set
password for a particular channel, that channel will be blocked.
to reset tv you might have to contact support at this link.
http://www.haier.com/servicesupport/index.asp
Apr 12, 2008 | Haier HLH15BB 15 in. LCD Television
2,575 people viewed this tip
Top Televison & Video Experts
Marvin
Marvin
