Tip & How-To about Kenmore 73952 Gas Dryer
How to access the start switch on a Kenmore 70 series dryer
The start switch on a Kenmore 70 series dryer sits directly behind the button you push in to start the dryer cycle, and it can occasionally go bad. Accessing this switch for repair or replacement is relatively simple; just follow the steps below. (These instructions were written specifically for the Kenmore 73742 heavy duty dryer, but they should apply to all of the dryers in the Kenmore 70 series.)
1. Unplug the dryer from the wall outlet.
2. Pull the dryer away from the wall so you have enough room to get to the rear side of the dryer.
3. Remove the rear access panel. This panel sits horizontally along the upper rear side of the dryer, and it is held in by six slotted screws. Put the screws aside, but do not lose them.
4. The start switch is located on the far left side (as you are looking at the rear of the dryer). It is a small black box with wires coming off of it. Disconnect these wires, but note which wire connects to which terminal for when you reattach them.
To remove the switch and button assembly as one piece, you'll first need to remove the knob from the front of the dryer. You should be able to pull the knob straight off, but if it's tight a pair of pliers might help. The round white plastic piece might come off with the knob; put it somewhere safe so you don't lose it. Then go back to the rear of the dryer and pull the black plastic tab (sticking vertically away from the switch) toward you to release it, and rotate the assembly clockwise until it pulls free from the panel.
To remove the switch from the button and housing, use a small flathead screwdriver to pry the switch up. Two of the four sides are tabbed; pry these two sides up to release the switch. There is a spring that sits behind the start button -- be sure not to lose this spring.
Kenmore 73952 Gas Dryer Logo
Kenmore 70 series dryer shut off in mid cycle and will not restart when I push the start button. any suggestions?
Hey GOD IS GOOD !!!!
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=sTRP6kHqAFs
Sep 14, 2014 | Dryers
Kenmore 70 Series Electric Dryer will not start
It sounds like the hi-limit thermostate and/or the thermal cut-off is what is causing your dryer to shut down. Basically it's over heating. You should replace these two items togeather. Also the thermal cut-off will be triggered by a grounded out heating element. Here is a diagram of where these items are located. hope this helps
Figure W-6: Dryer Rear Access
Feb 27, 2012 | Dryers
I have a Kenmore dryer 70 series. The buzzer won't turn off once the cycle is finished until I open the door. If I move the timer into the middle of the cycle and close the dryer, it will start again w/o me having to push start. How do I fix this?
It sounds like you have a faulty switch. The switch located behind the start button controls both the on/off setting and the buzzer. You can either replace this switch (which will likely take care of both problems) or you can take it apart and adjust the contacts. You can test them with a multimeter before and after to make sure you've got them adjusted properly.
Aug 21, 2010 | Kenmore 62602 Electric Dryer
How do you turn off the dryer signal on kenmore 70 series dryer
On a 70 series dryer, the knob on the far right of the panel controls the signal. You can turn it left or right to set the signal to "On" or "Off."
If you've set it to Off and the signal still comes on, that switch that sits behind the knob is bad. It's the same switch that controls when the dryer starts. You can either try to repair it (by bending the contacts back into their original alignment) or replace it. A new switch is less than $10, and you can get one many places online, including from PartSelect.com:
http://www.partselect.com/PartDetail.aspx?inventory=345390&SourceCode=3
May 20, 2010 | Kenmore 63942 Dryer
kenmore 70 series dryer wont start. I was going to replace the start button but cannot figure out how to get it off with out breaking stuff. do i need to pull all the panels off?
There is a switch that sits behind that start button. To get to it, unplug the dryer and pull it away from the wall. There is a metal cover that runs along the upper rear side of the dryer -- remove that and you will see the switch behind that button. You can disconnect the wires going to it (you may want to mark them) and pull the button off of the front of the switch. Then pull that plastic tab up and the switch will pop out if you twist it clockwise.
May 29, 2009 | Kenmore 60172 Electric Commercial Dryer
2,484 people viewed this tip
Top Kenmore Dryers Experts
Marvin
Marvin
Ned Halaweh
Ned Halaweh
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
