Tip & How-To about Fuji FinePix A360 Digital Camera
If your A360 only extends the lens partway when you turn the camera on in picture mode, there is an easy solution that requires no technical knowledge whatsoever. Mine exhibits this behavior most of the time, and I've experimented it with it and found that these two things help:
1. Hold the power button down the entire time the lens is extending. For whatever reason, this seems to help.
2. If your lens extends only partway (if this is the case the screen and all pictures you take should be blurry), simply hit the macro mode button (the little flower to the left of the zoom) twice. This works because when you go into macro mode, the camera automatically brings the lens to its lowest zoom, which is meant to bring the lens back from a high zoom, but also works in reverse. You may have to repeat this procedure a couple times each time you start the camera (you'll know it's fixed when you no longer hear the motor whine when you press the button).
One last tip: if you've had this problem before and you start up your camera and it seems fine, use trick number 2 anyways, just to double check that the lens is indeed in the correct position. I've made the mistake of assuming, based on the fact that the picture on the screen looked sharp, that the lens was fully extended. When you look at your pictures, you may find that all of them (even those taken with a tripod!) may be blurry.
