Tip & How-To about Xerox Phaser 6110 Laser Printer
Xerox Phaser 6110 Banding Cure
As usual, my Phaser 6110N (light use, home office network duty, printed less than 2000 pages in the 4 years or so I've had it) developed a banding issue. Rather than invest in a new toner unit, I decided to take it apart and have a look at it. What I discovered is the toner feed mechanism was clogging up and not distributing toner to the imaging drum.
This is a messy job, I did it in the bathtub (dry of course!), and it's simply a case of removing the side covers from the imaging unit (I'd recommend putting the drum in a thick black plastic bag to prevent overexposure) taking care not to lose any parts, and sliding the toner feeders out of the unit. You can then remove the top cover and it will allow you to clean out the mechanism with a small dry paintbrush.
Remove just enough to de-clog the mechanism, and especially the feed conveyor at the back - this takes toner from the cartridge and feeds to the roller screws that feed the imaging drum.
If you've only got banding problems with one colour, only de-clog that particular colour. It's messy and no point wasting expensive toner! Black and red where problems for me, in both cases the conveyor mechanism was chock full of toner and there was very little in the feeder roller screws.
Re-assemble the imaging unit and run a couple of test patterns through the printer. You'll probably find that the first few pages are especially faint - when you first power up the printer from new, it fills the feed mechanisms from the toner cartridge, I haven't found a way to make it do this again (maybe someone can hack together a maintainence firmware update?). The more you emptied from the feeder, the longer it'll take to even it up. Once it's got the page mostly covered, you're back in business.
After I'd done all this, my banding problem went away! Of course, the bath was covered in toner dust and it took a while to get rid of it all!
Xerox Phaser  6110 Laser Printer Logo
yellow streaks on phaser 7700 prints
You have a bad yellow developer housing and it will need to be replaced. The manual can be downloaded at: www.lpscomputer.com/ec/Phaser_7700_Service_Manual.pdf
The parts can be ordered here: http://www.lpscomputer.com/p-3063-1-116-1115-00-developer-housing.aspx
2answers
toners
Staples, Office Depot, Best Buy
phaser 8560 magenta ink not transfering to paper
Hi jbasset285: Your printhead may be bad do to third party ink.
Try these steps first.
Diagnosing Print-Quality Problems
The Troubleshooting Print-Quality Page provides a good overview of the most
common print quality problems. To print the Troubleshooting Print-Quality Page,
follow these steps:
1. From the Control Panel, scroll to Troubleshooting, then press OK.
2. Scroll to Print Quality Problems, then press OK.
3. Scroll to Troubleshooting Print Quality Page, then press OK.
The Troubleshooting Print Quality Page includes instructions for printing the
Eliminate Light Stripes test print. These instructions are also provided on the next
page of this manual. The Eliminate Light Stripes test print indicates individual weak
or missing jets or an obstruction in the imaging path that affects a vertical band down
the entire page. Also, you may see color variation from jet to jet on the Eliminate
Light Stripes test print. Some variation is normal, occasionally occurs, and usually
self-corrects within a few printed pages. If a print-quality problem is not resolved
with the information provided in the Diagnosing Print-Quality
Xerox 7700 intermittant banding on a diagonal black only
You most likely have a bad black developer housing.
You can try removing the waste bottle and using that bla\ck stick inside the cover to clean the laser ****.
But it sounds like the developer housing has failed.
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
