Kenmore 24032\24036 Top Load Washer Logo
Posted on Sep 02, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kenmore 80 Series Top Load Washer not agitating
I have a Kenmore 80 Series top load washing machine model # 110.25862400. The water fills, but it doesn't agitate. Just makes a loud screaching noise.
  • 2 more comments
  • nraether27 Dec 20, 2008
    I have a Kenmore 80 Series top load washing machine model # 110. coupler is cracked and spin cycler won't spin loud grinding noise. need assistance on parts and how to replace coupler.
  • Anonymous Mar 13, 2014
    ob code & S1 or Sl code
  • Anonymous Mar 14, 2014
    ob code & Sl code how much are parts for these problems
  • Anonymous Mar 17, 2014
    Kenmore 60 series Model 110 won't fill with water. Skips fill cycle altogether and goes to agitate. What part do I replace? Thanks!
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Dec 20, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1805
Points
11
Check out this you tube. Had the same problem today. Tipped washer on its side and replaced coupler between motor and gearbox. Parts are about $15
This is a good diagnosis video.
http://www.youtube.com/watch?v=VYOP0_KCYT0
Anonymous
Level 3:
Genius:
  • Master 1,028 Answers
  • Posted on Sep 03, 2008
Anonymous
Master
Level 3:
Genius:
Answers
1028
Questions
Helped
316712
Points
2631
If it will pump out ckd motor to gearcase coupling probably broke
1helpful
Kenmore 80 series washer. Agitates immediately and does not fill
it sounds like the water valve is bad,the water valve level(sm. med. lg.)controls the water valce-mike
Machine agitates but doesnt spin or pump out water
you will need lid switch 285671.. whirlpoolpartssurplus.com
1helpful
Washer won't spin
pull the fab soft dispenser out and pry off the cap that sits on top of agitator looking down inside there you'll see 4 pieces called agitator directional cogs(dog ears) they are worn and need replaced
3helpful
1helpful
Kenmore 80 Series will not fill up with water
if your washer will agitate when set to fill but not fill, then your pressure switch is bad.
also you may want to check and see if you are getting both hot and cold to your washer.
Kenmore series 80 washing machine
This is usally a timer problem that is shorted
Hot water wont shut off
solenoid valve is jammed open
replace
Alexander
vince
