Hello, Your Maxent MX-42EPM20 is not a TV (Television) it is a Plasma panel. The difference being your Panel does not a TV Tuner (no Coax jack or electronics relating to a tuner) Below is the spec sheet that shows this http://reviews.cnet.com/flat-panel-tvs/maxent-mx-42epm20/4507-6482_7-32139310.html?tag=mncol;subnav
You can use a cable box or a cheap Digital TV receiver. You can buy them at walmart, You need one with A/V out puts such as Component. Here is a link to one. This will give you a tuner. http://www.walmart.com/ip/RCA-Digital-TV-Converter-Box-DTA800/8343230
Are you sure that its the main A/Vboard coz it sounds like the main power supply issue to me. Anyways the mainboard is the large board usually located at the center of the tv. If you can remove the back cover of the tv and get me a high res picture of the tv I can mark the board for you.
I hope that you have gotten this resolved, but if not, or if you have any other questions, here are the codes and some simple steps to run through.
1. Hold down the clear TV button until all lights light up at the top of the remote 2. Punch in a 3 digit code (provided below) 3. Press the # (POUND) button 4. Try powering the tv on/off, and the volume. If one or more of these functions do not work, start over from step 1 with a different code
The TV was made by LG. You should be able to google an LG distributor or try ebay. The 953 is readily available but the 917 may be hard to find. Won't be cheap for new ones, around $350-$400 for both unless you can find used.
I was looking for codes for you but cant find any compatible ones!
You can order the orginal remote for your TV at www.remotes.com
Have make and model ready!
Hope this is a fix ya solution for ya!
