Maytag PAV2300 Top Load Washer Logo
Posted on Aug 05, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I was given a Maytag Supreme Model PAV2300 awa by my son. How strong is the pump in the machine and how high can the waste water be pumped?
Anonymous
Level 3:
  • Master 2,341 Answers
  • Posted on Aug 05, 2011
Anonymous
Master
Level 3:
Answers
2341
Questions
Helped
636393
Points
7414
For most all wasing machines the maximum height is 8 feet
I have a maytag pav2300 pump will not pump
see this causes:
It spins, but doesn't pump
drain line is clogged, remove some sock with pliers+test the pump for defective propeller, and replace DO NOT REPAIR
It doesn't spin or pump
frozen pump puller +and replace the pump
It pumps, but the water returns
if the drain hose reach more about 4 inches, cut of the excess
if the hose is lower, install air/gap siphon break assembly
see the diagram.
God bless you
Can't find where the clutch goes on a Maytag Performa PAV 3300, is it in the transmission?
This washer is a single belt driven model that uses a thrust washer system to release the brake when the motor reverses. In wash mode a 200# spring locks the tub place while the transmission agitates the clothes. The pump cannot remove the water in this direction. In spin mode the the brake is released and the water gets pumped out. Here is a great pictorial that shows how to replace the kit along with a Maytag single belt washer service manual.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
1helpful
Pulley and bearing removal of water pump on a maytag pav2300aww washing machine
the pulley and bearing are not removable on your pump. it is replaced as a complete pump assembly.
I m using maytag pav2200agw after fill the water washer is working fine but during the spin dry cycle water pump does pump out the water and start spin but the tub is not moving its not working propperly...
I WISH I HAD SOME ANSWERS ON THIS ONE, BUT IT SOUNDS LIKE YOUR PUMP MIGHT NEED REPLACING. HOW OLD IS YOUR WASHER? IT WOULD BE CHEAPER TO BUY A NEW WASHER. BUT IF IT IS THE PUMP, THEN YOU CAN BUY A NEW PUMP FROM WHERE YOU BOUGHT YOUR WASHER. GOOD LUCK.
RODNEY
1helpful
Maytag SAV 3652 AWW Washer: During spin cycle, burning smell occurred while making unusual noise. (For months, major squeaking during agitation).
Bad water pump. Replace water pump.tip machine back,Look under machine, remove belt, turn pump by hand, if not spinning freely replace pump.
Leaking water for washer machine
Check your drain, drain hose (make sure the clamp is tight) and check the pump to make sure that all hoses are attached properly
Washer spins freely but clothes remain very wet
The two possibilities of which come to mind are, something in pump slowing the water outlet, belt loose or needing replacement. Sometimes an article gets over the barrell and sucked into the pump still allowing some water to pass by, but the belt needing to be replaced would prably be my first check. both need Power disconnect then cabinet panel pulled to view both the pump and belt
Washer noise
Bad pump. Tip the machine back and remove the belt. Turn the pump by hand and check if it is locked up.
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
