I am sorry to hear regarding the trouble.
Image problems on Plasma TVs are usually a result of a failure of
fault in the screen buffer boards. There are several buffer boards and
each controls a section of the screen: either a column so many pixels
wide or a row so many pixels wide. When the buffers start to fail, it is
common to see lines either from top to bottom, or from side to side or
just portions of a line going halfway across.
You are
going to have to call in a pro to check this out. There is no way that
someone over the internet can correctly diagnose the TV without being
there in person and then it would likely take hours of diagnosis to
narrow down the bad part.
It's probably your buffer boards.
If you have electronics repair experience and would like to conduct the repair, revert and i would be able to add few more inputs.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
