Problem first started out having purple shots in the picture and now it is just lines. It acts like it is a bad signal, but I hoolup and other TV and picture is great. I try to select anyother input to see if DVD would work and nothing.
Thanks Clint Yost
[email protected]
SOURCE: RCA rear projection tv
Dir TV projection Techcions, I own RCA Model:P52937 Chassis No.PTK195M26B. After a big flood here in Chicago, my basement got flooded and my projection TV was in water up to 1 foot. Befor I turned it on, I dreid it out perfectly, then, I turned it on, and a couple components from the power supply got burned up to the point where I am not able to read the part numbers that are on it. I was wondering if you have this kind of chassis and model service manual for this projection TV, or conponet part number i location 101 on mother boatd power supply. Thank you in advance, Darius If you prefeer, you may call my cell phone: 773-875-3926
SOURCE: l46wd22 rca 46" flat screen
ok....i know what is wrong with your set.. it is a small (very small micro fuse. rca has issued bulliten to service centers on the problem.. getting the fuse and describing where it is then soldering might be the difficult problem here.. but let me give it a try. it is located on the main signal board in a shelded covered board called the main signal board. The fuse, 1C33,is located approximately 2 inches behing the tuner
The surface mounted part has various markings on
the original part from “105” to “F”
and is located below the board marking “7C32'
Replacement fuse #275819 can be placed directly over the top and soldered to the ends of the existing fuse
to lessen the chances of damaging the board traces.
all that being said.. this is some trick soldering.. and unless your a tech i would not recomend such a repair.. i cant speak for all shops but such a repair is not that difficult for most techs and cost about 125 to 200. So good luck and let me know how it go's or if i can give any more detailed info
SOURCE: "UNUSABLE SIGNAL"
l have a 42 in tv rca connected from a direct satellite and i have no picture or sound tryed different connecters only black screen with unsable signal
SOURCE: RCA SRS Focus turning on and off
the best thing you can do is take it to a shop and have it repaired as the problem has gotten worse..
