Question about Cameras
Grainy looking photos
I'm getting grainy looking photos on the camera when i view them and as well when i upload them to see and ssend them. I love to take pictures and have never seen this before and dont know how to fix the problem. I have a Sanyo C-S600 Digital camera
  • 31 Answers
Reset the camera to factory settings
set everyting automatic
then try.
Also if your day photos are good then its the ISO Setting
Posted on Jan 06, 2009
  • 81 Answers
The first thing I'd check would be the ISO setting. If it has the capability of changing that, the go with a setting of 100 or lower. The higher the ISO, the more digital noise you will get.
Hope this helps!
Posted on Sep 03, 2008
6ya staff
SOURCE:
Why low resolution?
Uploading them via the SD card will have no effect on the resolution.
There is a difference between image grain and image pixelation.
If the resolution is too low for the size you are printing the image will pixelated, meaning that it will be made up of lots of little squares.
If the image is grainy it may be that you are shooting images in low light at a high ISO setting on the camera. Typically with the lower end Canon cameras anything above 800ISO will start to look grainy.
Jun 19, 2012 | Canon EOS 500D / Digital Rebel T1i Digital...
Fujifilm finepix f20le. circular grainy pic loss of sound
First go to the SETUP menu and make sure that the PLAYBACK VOLUME setting is set to a value greater than 0. Try increasing the shutter speed of any photos as CCD's will notoriously produce grainy images on slow shutter speeds. Grainy videos will indicate poor light, camera shake during filming or moving too quickly so the autofocus cannot function correctly, or using too low a resolution and will be especially noticeable at 640 x 480 when viewed on a large high resolution screen. If all the above make no difference then you may need to get the camera serviced.
Oct 08, 2009 | Fuji FinePix F20 Digital Camera
Grainy photos with canon 350d
Set up a cleaning session on the sensor frrom settings and see if that improves it
Jul 28, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Video looks grainy and pixelated when uploading to youtube
It appears that the solution is to wait a few days (5 in my case?), and then view the HD version.
It'd be great if YouTube would let you know that it may take a few days to make a better version available =)
Dec 31, 2008 | Pure Digital Point and Shoot Video...
Photos pinkish and grainy whne printed and viewed
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Dec 29, 2008 | Canon PowerShot A75 Digital Camera
INSIDE PHOTOS ARE DARK AND GRAINY
Regardless of the camera make/model... dark, grainy photos are usually a result of a lighting problem. Looking at the specs for your camera, the flash is only speced for 4m. If you are shooting near or above this you might have trouble. I ended up using an external flash that is triggered by sensing the cameras flash. Pretty inexpensive and pics ar 10x better. Try a local camera shop or B&H Photo (NYC) is where I got mine set up on line.
Jul 24, 2008 | Canon PowerShot A630 Digital Camera
Re-Sized Photos are Grainy
This camera takes pictures with a Ppi of 72. That is why the pictures look huge on the screen. To get good quality prints you need to have at least 200 ppi, or even better, 300 ppi.
Or, the contrast of the pictures may be to low. I have an FZ7 too, and I always tweak the contrast and color saturation before outputting.
1. images straight from the FZ7 are generally low in contrast.
2. Pictures that are low in contrast might not look too bad on screen, but when they are printed they will look slightly greyish.
3. Low ppi pictures look fuzzy in print.
Maybe you can post a sample original picture??
Jul 06, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
Very grainy pictures indoors at night
If you can adjust the ISO sensitivity to a lower number then the graininess will be reduced.
However, by reducing the ISO, you will need a slower shutter speed and a larger aperture. A tripod, table or other support may be necessary.
The "noise reduction" setting on the camera can also be adjusted a step up.
Taking pictures at full resolution and fine compression will also help.
Overall, at least try lowering the ISO, and using the flash brighter.
Jul 01, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Photo quality
It will be grainy a bit specially in digital zoom and even in optical zoom to the full level it might become grainy as camera is unable to absorb all the light from distant object......
May 04, 2008 | Canon PowerShot SX100 IS Digital Camera
Grainy Photos using Natural Light
Sounds like the 'shutter speed' as it was called is too fast.
Jun 23, 2017 | Nikon Cameras
Cameras Logo
299 people viewed this question
Top Cameras Experts
Ekse
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
