Televison & Video Logo
Posted on Dec 20, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Toshiba TP48E50 Projection TV - Power light blinking no sound or picture. All plugs are stable and power sources are good. Cable is on as are all other equipment. Remote is fine. Without picture or power to main screen cannot tell what channel TV is set to. Any suggestions?? Before I call repair service.
lolthepcman
Level 2:
Sergeant:
  • Expert 179 Answers
  • Posted on Dec 20, 2017
lolthepcman
Expert
Level 2:
Sergeant:
Answers
179
Questions
0
Helped
182837
Points
842
Put your remote down and dont use it. disconnect the power at the plug. wait 30 secs. reconnect the power at the plug and use the ON button of the TV, see what happens. only then try remote. a TV is never OFF unless its power is disconnected even when the remote tells it to go off, its still in standby and what it needs is a proper OFF for a while.
5 Related Answers
Dewayne Turner
  • 87 Answers
  • Posted on Aug 02, 2007
SOURCE: Blinking power button
You likely have bad convergence output IC's that have caused one of the supply fuses to blow. This repair will have to be performed by a qualified technician. If you were in our area and has us repair this the total cost of the repair would be about $340 if I am correct about the cause of your problem.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Anonymous
  • Posted on Dec 19, 2007
SOURCE: TV on/off light keeps blinking red light/no sound or picture on screen
Here's a solution that I received from an TV expert in another website: "This sounds like a power supply problem. i have seen it several time on your model. i would not keep trying to turn it on it might damage something else in the tv. the reason it is shutting off is because the power supply is putting out too much voltage. a repair cost will range around 300-400. this is a great model and well worth a repair. here is a web site that might help you in finding a repairman.
http://www.nesda.com/locator/state_search.php." <-- $300-$400 is too much! But throwing away a 300lbs TV will cost a lot of $$$ for the towing and dumping too. I haven't decide what to do yet.
Anonymous
  • Posted on Apr 09, 2008
SOURCE: Toshiba 42H82 RPTV: Sound but no picture
I have the same tv but the picture is being squished down a bit, maybe 20% down the screen. black bar across just the top, and the color is off any suggestions?
Anonymous
  • 239 Answers
  • Posted on Mar 04, 2009
SOURCE: Sony KDS-60A2000 projection TV: power led blinks 4 times
the projector bulb has gone out you need to replace it.
hope this helped
please rate well
If you need further help, reach me via phone at https://www.6ya.com/expert/mark_445a24324be9eb03
Ambari
  • 901 Answers
  • Posted on Apr 07, 2010
SOURCE: No picture/power
It is fixable. Contact the service center for assitance.
When i plug tv in clicks a few times doesnt power on ,and power light keeps blinking
power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Good luck in solving the fault...
1helpful
Will not power up. Red power light only blinks.
If you have sound and no picture, it's time for a new lamp.
In the manual check under LED indication, It explains the blinking lights, unless your outside at night looking up!
Red power light continuously blinking. no picture no sound.
It could be the lamp went out and needs replacement. The Toshiba website states when this happens to unplug the televison for 10 minutes then plug back in. If that does not work then try another power outlet. If that does not work then call for service
Pop sound and now no picture or sound still gets power
Try disconnecting all the cables from the TV then reconnect them after a few minutes. It's suggested that you connect the power cable from the TV directly to a functional wall outlet.
If still there is no picture on the TV then it's required to replace the projection lamp.
2helpful
I have a toshiba tz50v51 projection tv. the red power light is on
It could either be due to the convergence Circuits ( If the Power Indicator Blinks) or the power deflection board if it doesnt blink. I have a source for parts if you would like the link.
Toshiba TP48E50 red power light flashing
hello there well form my prior experiences and ive had many...i would suggest checking high voltage maybe the horizointol output or try checking the flyback for shorts...it is in the power suppy.......hope this helps..someitmes these sets have codes and the blinking light in the front panel may indicate the problem..see how many time it blinks in intervals and then see if you can check out the codes on the net....
2helpful
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Toshiba tp48e50 powers up but no video
I believe this is a projection TV, personally I would look for a new set
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
