Question about LG Heating & Cooling
LSN092HE Mini Split. Inside unit working fine except that is leaking water from underneath the face of unit. Have blown coils clean with air pressure and tried to clear drain line from outside using shop vac and have blown air back into unit to attempt to clear drain line. What could be cause?
    New Friend:
  • 20 Answers
Did you check to see if the unit is level? It needs to be.
Posted on Aug 08, 2011
6ya staff
SOURCE:
Brand New 2 weeks old 4 ton Trane compressor leaks a lot of water onto pad
If the unit is running in cold weather than there is ice building up on the coils located outside. This is normal in that the unit is running in heat pump mode heating inside and cooling outside, After the unit detects the ice build up it briefly reverses the cycle heating the outside coils melting(defrosting) the ice which you observe as water on the pad.
The video gives you an example of the defrost cycle!
2012 Trane XL15i Heat Pump Defrost Cycle Steam Show
Dec 21, 2015 | Heating & Cooling
Why does inside coil frost over within 10 minutes of turning on ? we are having a problem with water leaking inside
first check and make sure the inside blower is running if so check to make sure the filter is clean if that's not if it may be low on Freon charge or the evap coil is dirty.
Sep 26, 2015 | Daikin FTXS12LVJU/RXS12LVJU 12000 BTU...
Water leaking from unit
possible low pressure of refrigerant and freeze coil indoor unit, check filter maybe it's dirty
Jul 07, 2015 | YMGI R410A Ductless Mini Split 16 SEER DC...
My carrier split ac trip after some time and green light blinking contsly
If this is a ductless split call a tech! The ductless split systems can be a troublesome unit to diagnose. A few things to try. Clean air filters and ensure coil behind is clean. And build up or debris on blower wheel (indoor fan blades) will cause unit to fault. Turn off power at breaker or disconnect and clean (with water hose and medium pressure) the outdoor coil. Be sure you will not damage outdoor coils fins with too much water pressure. Turn power on. If this simple service don't do it again, call a tech! Be sure to ask if they have someone who is experienced with mini split systems and be patient. Even the best technician will need to call carrier for tech support.
Jun 04, 2015 | Carrier Heating & Cooling
Cooling doesn't stay on
The outside and inside coils may need cleaning. Clogged coils cause excess pressures and heat of the freon that can cause safety switches to shut er down. Eveen a faulty power relay in the outside unit.Otherwise you may need a serviceman to locate the cause.
Jan 21, 2012 | LG LS-L1210CL Mini Split Air Conditioner
My Panasonic split system inverter is leaking water from the inside unit
condensate drain is stopped up and if older than 6 yrs, need to remove the unit and clean coil and pan with high pressure water
Mar 24, 2011 | Panasonic CW-1006FU Air Conditioner
The inside unit is leaking water
Water leaking in split unit common, due to air filter & evaporator coil dust blocked- Clean it.
Drain pan and drain hose dust blocked-clean it. And also due to less rpm of indoor motor, there will be forming ice over the coil result to water leaking while defrosting.Replace motor capacitor.
Dec 27, 2010 | Fujitsu 24C1 Air Conditioner
Our Mitsubishi Mr. Slim split a/c unit is wall mounted and is leaking badly from the bottom left side inside our home. We have to use a bucket underneath the unit to catch the leak. Please help us to fix...
Reason for water leaking.
1. Filter block. 2. Cooling coil block. 3. Alignment of indoor a/c unit is sloping downwards. 4. Drain pan block. It's advisable to service your unit first.
Dec 06, 2010 | Heating & Cooling
My split air con unit is leaking water from the unit in house
The things that you can check yourself are
is the indoor unit level?
Are the filters clean?
The area the water is draining to free of obstruction?
Is the drain actually draining?
----Get a cup of water and pour it over the indoor coil (please make sure the power is off first please) If the water does drain then it is prolly a bigger problem.
Prolly your unit is short of gas and need a refrigeration tech out to check. That it isnt ice-ing up but you would notice the performance drop.
Hope this helps
Jan 05, 2009 | LG LS-L1210CL Mini Split Air Conditioner
Hi my split airconditioner is leaking water inside the house
YOU DRAIN IS STOPPED UP, FIND WHERE YOUR WATER DRAINS OUT AND CHECK THE END AND SEE IF IT IS BLOCKED OR YOUR DRAINED IS STOPPED UP INSIDE WHERE THE COIL IS.
Heating & Cooling Logo
124 people viewed this question
Top LG Heating & Cooling Experts
Felizardo Erilla
Felizardo Erilla
Steve F
Bill Long
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
