Question about Yamaha Full-Size Keyboard
Yamaha digital piano clp 170
One of my piano keys is making a loud note when played (louder than the rest) - I suspect there maybe some sort of dirt on the contact beneath the key- is there any way I can fix this myself rather than spend a fortune getting someone in?
  • 5 more comments
  • roseortega Sep 05, 2008
    I have the same problem just instead of one I got three notes that sound loud
  • michaelzebro Sep 10, 2008
    I also have a few loud keys....sounds like a bad hammer hitting a string on a conventional piano. This situation just appeared after many years of playing the instrument with no problems. Do the weighted keys need some sort of periodic maintenance, and if so would this maintenance solve my loud key problem? Many thanks.
  • Anonymous Sep 22, 2008
    I have PSR 9000 in very good condition,but I have the same problem with one key,it sounds louder.It seems the dust or some kind of uncleaning problem.
  • fairbairn Feb 21, 2009
    Hi we have keys sticky and staying down on CLP170. Help with any ideas. contact Brian at fairbairn@xtra.co.nz
  • Anonymous Mar 24, 2009
    Fixing a buddy's CLP-123 which has sat broken for years. Only half the keys actually worked. Same problem... I got the entire thing apart and cleaned the circuit board contacts with WD-40 and attempted to clean the rubber strip as well (with wd-40 again-- hey i'm cheap) but the cleaning did not help much on the rubber/silicone... I can still see it is imperfect. After my cleaning, however, only 8 keys fail to function... better than half not working, but if you can't get all of them, who cares anyway? on this model, you can turn the keyboard upside down once you take it out of the piano and you don't need a dowel, you can just remove the boards easily.
    I think these rubber strips are meant to be replaced when they get bad... I'm not sure that any product could clean the one in this unit.
  • Anonymous May 11, 2009
    i have a portable yamaha keyboard, and the key when pressed has max volume over against the other keys. i then noted that yamaha uses rubber boots with contacks inside. so then i moved the rubber boot strips around and noted that the problem followed a given strip.
    however i dont know if i can just buy new rubber strips.
  • Jon Bruce
    Jon Bruce Nov 04, 2013
    I also have three notes that are bad, and one other is going. Use a philip's screwdriver to take it apart, that's what I'm doing.
This is a common problem with Yamaha keyboards. The problem is caused by worn-out rubber contacts in the keyboard assembly. In my old Clavinova CLP-500, there was one long rubber contact strip under the keys with two parallel strips of semiconductor material. The Clavinova circuitry determines key velocity by measuring the timing between when the key hits the first and second strips of semiconductor material. The harder you play a key, the less time it takes the key to hit the second semiconductor strip after hitting the first.
After years of playing the keyboard, the keys eventually cause tears in the semiconductor material and this messes up the timing measurement for key velocity. The only solution is to take the keyboard apart and replace the rubber contact strip with a new one.
I got rid of my CLP-500 four or five years ago and got a new CLP-170. The CLP-170 is now having exactly the same problem that the CLP-500 had. Yamaha has re-designed the rubber contacts in the CLP-170 so that there are now eight individual contact strips instead of one long one. The problem is essentially the same, though. You have to take the keyboard apart and replace the worn out rubber contacts.
Here are the part numbers for the rubber contacts that need to be replaced in the CLP-170: V8286600 Rubber Contact, 12 keys, D-C#   Qty. 6 V8286800 Rubber Contact, 11 keys, A-C#   Qty. 1 V8286700 Rubber Contact, 5 keys, D-C   Qty. 1
I suggest you also get a copy of the CLP-170 service manual, part number 001677. It has descriptions of all the steps necessary to take the thing apart and put it back together again. You'll also need a "rod" (which is just a long dowel), part number TX000670. Before you take the circuit boards off the keyboard assembly, you have to insert the dowel between the keys and the frame to keep the keys from falling back and getting in your way. A 5-foot long 1/4-inch dowel will probably work. (I haven't yet taken apart my CLP-170, and I don't have Yamaha's "rod," so I'm not sure if 1/4 inch is the right size or not. I'll report back here if it's not.)
Good luck, Howard
Posted on Sep 27, 2008
  • Merv
    Merv Nov 02, 2011
    thanks man, my clav 170 is doing the same so lloks like i'll have to change mine.so a quick clean air spray between the keys wont do then? i bought mine from new 6 years ago. where is the best place to buy the part? i live in brighton england
    New Friend:
As a Yamaha warranty service technician for over 10 years, I can assure you that WD40 is NEVER good for vinyl contacts and there is no semiconductor material, save for the diodes, on the key contact assembly. Take preceding advice with a grain of salt, there people seem to be quite ill-informed.
Posted on May 07, 2013
  • mckimani Aug 26, 2016
    WD40 SHPULD NEVER BE USEDTO CLEAN YAMAHA CONTACT BOARD OR RUBBER CONTACTS.
1) Clean the circuit board contacts under the keys (where the strip hits). Use wd-40 first (for possible rust), then soap and water (for sugars--don't soak the thing though), then follow up with rubbing alcohol (to remove moisture)
2) Replace the rubber strip. (You will need to order this part from a Yamaha dealer). I tried cleaning this, and was able to get every key working again (by themselves), but it the strip wears down and you will get random notes when you play CHORDS. Ended up having to replace it. Now its 100% working.
Posted on Apr 10, 2009
    Passionate:
    Visited the website for 10 consecutive days.
    Habit-Forming:
  • 65 Answers
Sounds like the rubber contact underneath is worn out. You may check for Yamaha CLP-170 spare parts in this link:
Yamaha CLP 170 spare parts ArtAudioParts com
Posted on Jul 28, 2018
    New Friend:
  • 45 Answers
TORN RUBBER CONTACT,OR DUST, CLEAN OR REPLACE THE RUBBER CONTACT
Posted on Aug 26, 2016
Me too. I thing I have to open the piano somehow and clean something inside or under the keys
Posted on Sep 13, 2008
6ya staff
SOURCE:
Key B2 playing to loud, not touch responsive
What is your piano brand and type?
Damage to the contact rubber can cause note plays loudly or,
note does not plays at all.
It is caused by:
1. Carbon rubber contacts dirty / dusty (yellow arrow). Clean with a pencil eraser (or cloth). Gently rub it.
2.
Contact rubber is torn (your case). If this happen,it can not be repaired or glue. So, you have to replace one octave.
The yellow arrow indicates the side that is often torn.
Rubber side that is torn, usually not seen, unless we move / pressing gently on top (In the rubber contact position is not installed on the board.)
Examples of this picture was yamaha psr.
Oct 14, 2015 | Music
There is one note, the B below middle C, which is much louder than all the rest. Please advise how to rectify this. Many thanks
If your keyboard is a few years old then it is likely that the pressure strip that runs under all the keys needs replacing. This will cost around £50 to pay someone to supply and fit.
Mar 12, 2015 | Yamaha Used Arius Ydp140 Digital Piano...
Yamaha P-70 digital piano. A few keys are making a loud knocking noise. The note still sounds, but the knocking noise on the few keys can be heard at the other end of the house
There's an extremely comprehensive pair of videos about repairing this problem on YouTube thanks to David Allyn. I have embedded them below, or you can search "P70 Noisy Keyboard Repair".
Jan 03, 2014 | Yamaha NP 30 76 Key Lightweight Digital...
MY YAMAHA P-95 PLAYS NOTES i DONT PRESS
Haha yes - I know the feeling...fingers are nowhere near the keyboard the "BANG!" a note or a cluster of notes happens out of nowhere! :)
Easiest solution will be to take it in to our local Yamaha Dealer and have them clean the contacts. Dust and hair can get between the keys and cause all sorts of problems with the sensors/contacts.
I have learnt to clean them myself using a photographic blower brush, and if you're daring, give it a go. If not - don't risk it :)
Nov 30, 2013 | Yamaha P95 Digital Piano
Yamana DGX 630 E keys make strange sound
Perhaps the performance assistant technology is turned on.
Press the [PERFORMANCE ASSISTANT] button to turn it off.
Jan 12, 2013 | Yamaha DGX630 - Digital Piano
I have a Yamaha P70 digital piano and one F and F# stopped working. Then the adjacent G,A,B,C ansd the sharps inbetween would only work sometimes - ususally after the piano had been on for awhile. The...
I just experienced my p85 with a key problem on the F# below middle C. You will need to disassemble the keyboard and usually the keys are groups of 6 - 8 keys. If you remove the group that has the problem you might be able to find the problem visually. Mine just involved removing and reinserting the F# key back into the assembly. Then reinstalling the group of keys. If you can't get the key to work properly, you will probably need to buy the group assembly from Yamaha.
Jun 11, 2012 | Yamaha P85 88Key Portable Digital Piano
Our Yamaha clavinova CLP-115 is buzzing, even with
Without power to the unit no sound should be generated. Make sure there are no other connections.
MAYBE you have a wall transformer behind it that is buzzing. MANY wall transformers develop buzz.
Another source is flourescent lights and even some of the low voltage halogens have noisy transformers in the base.
Nov 17, 2009 | Yamaha Music
Yamaha 88 key piano grand plays wrong pitches w/ changing volume
If it has a sequencer/ recorder built in, you have the ability to change the pitch/ detune by using some key strokes after initiating the program mode. If your not sure how to do that, try unplugging the keyboard for thirty seconds and push the power button while it's unplugged, then plug it back in. Any better? What model is it.
Jan 01, 2018 | Yamaha Full-Size Keyboard
Yamaha clavinova won't play C natural in any octave
Hi ...
There are flexible cables that connect the keys to the main electronics. The connectors for those cables sometimes age poorly..
It is fixable. But dont "get taken" on a repair.
If it's just resoldering a few points,it shouldnt be more than $100.00
to fix
Jan 04, 2009 | Yamaha Full-Size Keyboard
Yamaha Full-Size Keyboard Logo
19,344 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
