Leica DISTO A5 Rangefinder Logo
Posted on Aug 09, 2011
My Leica Disto A3 keeps showing the error message 290 with a spanner. i appear to have mislaid my manual could you assist please.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 18, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2339
Points
Try cleaning the lense it worked for me.
What does error 270 mean?
There is no error code 270 listed for a Leica Digital DISTO D3a 100M Laser Distance Meter.
Are you sure that's the code?
Or do you have a different make or model of laser distance meter?
Leica disto
Low battery. Mine does that when batteries are too low to operate the laser.
Aug 20, 2013 • Optics
1helpful
Leica Disto D3a shows ERROR 220
I had this exactl problem and resolved it by replacing the batteries
Solutions for Leica DISTO A5
hi,my disto A5 IS ERORR 206.I M IRANIAN.PLEASE HELP ME.
EMAIL:[email protected]
Always get error 279 on my Disto Classic
Put in new batteries and clean lens and calibrate if it has that function. If that doesn't work, Type the " Leica Disto A6 Laser Distance Meter user manual" and it will bring up sites to manual.
My disto a8 tilt sensor is not working at all, its only the tilt sensor thats not working everything else seems to be working ok. when I try to turn on the tilt sensor- error 163 with a spanner symbol...
if it is still under warranty then you are simple if you do not have it repaired under warranty
it could be a major fault but as soon as you carry out a fix the warranty is void regardless of the fault
while everything else appears to be working , there could be something else somewhere that is the actual cause of your problem
1helpful
Leica disto A3 button broke
Mike,
Leica does not sell replacement keypads, if the unit is less than 2 years old they will cover it under warranty. Contact the dealer you bought it from and they can handle the warranty exchange. If it is over two years old, it is out of warranty, but they offer a "repair" option, which will replace your damaged A3 with a new D3 for about $215. If you bought it from a reputable dealer, you shouldn't have any problem.
Hope this helps,
Greg DeTray
www.distagage.com
Disto A3 - problem acquiring readings over 3-4m
A short rectangular "dot" is normal, a 255 error indicates that you are not getting enough reflection back to the optics. This may be due to the surface you are aiming at. Try placing a piece of white paper over the surface, if it does not measure 30 or 40 meters to a sheet of white paper, indoors, and the optics are clean, I'd contact your dealer to initiate a warranty claim. 3 or 4 meters should not be a problem unless the surface is very rough, such as dirt or sand, or very dark color.
If you just bought the unit from a licensed distributor, you should have at least a two year warranty, possibly 3 years.
Greg DeTray
www.distagage.com
29helpful
3answers
Getting error code 279 on my Disto Classic 5a
can not measure distance.
each time the button is pressed dist, 279 error appears.
Top Leica Optics Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Tony Parsons
Tony Parsons
Are you a Leica Optic Expert? Answer questions, earn points and help others
